I have a 1979 Ford F-150 Ranger Lariat 4WD. I am trying to figure out what axles are under it. I'm sure the rear end is a 9 inch with 3.50 gears. Here's the info. The tag in the door reads 16A for the axle. The front axle's tag reads 3.50 D9TA AAA and 610047-4. The rear axle was more difficult with a small tag reading 8G25, an upside down 74 stamped directly into the case and the tag reading WDM-C with 3 50 underneath. The rest of the tag is obviously broke off. Thanks for any info you guys have.
Thanks a bunch you guys. I am running 10.5X31.00-15R tires on a 15X8 rim and am thinking about going with 12.5X33.00 tires on these same rims. Would I need to change my gear ratio from 3.50 or is it fine. If so what would be a good ratio?
