1978 - 1996 Big Bronco
axle tag code
Old Apr 15, 2005 | 10:19 AM
crash71us's Avatar
crash71us
Arrow axle tag code
i can not seem to find any info on this axle.please help. it is a 1980's 9" out of a ford van. first line of the tag wev az2 4a27 second line 3 50-9 s716p.i want to know if it has pozzy or limited slip or open?also what spline axles it has? thank you for your time and info.
Old Apr 15, 2005 | 09:14 PM
Trublufords's Avatar
Trublufords
All Ford tags that have limited slip carriers Always read 3L.55 ( or what ever ratio you have)Call your local Ford part dept for more help- my dealership gets calls about every day about things like this- If we at FORD can't answer(free) questions like these from time to time- its real hard to make you one of our customers!!!
Old Apr 19, 2005 | 01:51 AM
justshootme84's Avatar
justshootme84
The second/bottom line of the tag gives you the ratio and make of the axle. It is a 3.50:1 ratio, not equipped with factory L/S (no "L", like "3L50..."), Ford 9" axle. To my knowledge, all truck 9" axles after 1970 are 31 spline, not sure about the vans. I do remeber something about the van axle being unequal length or one side is a couple inches longer than the other. IF you're swapping it into a Bronco it can be a headache! If you search for "Ford 9" axle", many of the parts vendors have decoders/ charts, and more info on each year and model of axle.
bigperm2
47
Jun 2, 2026 11:45 AM
randyein
Oct 8, 2020 03:59 PM
williamsportwrestler
Jun 3, 2010 08:21 AM
johnson2007
Aug 18, 2009 02:59 PM
rocktown1980
Nov 23, 2008 09:11 PM
