Axle Identification
Axle Identification
I have a 1979 Ford F-150 Ranger Lariat 4WD. I am trying to figure out what axles are under it. I'm sure the rear end is a 9 inch with 3.50 gears. Here's the info. The tag in the door reads 16A for the axle. The front axle's tag reads 3.50 D9TA AAA and 610047-4. The rear axle was more difficult with a small tag reading 8G25, an upside down 74 stamped directly into the case and the tag reading WDM-C with 3 50 underneath. The rest of the tag is obviously broke off. Thanks for any info you guys have.
on
According to:
http://www2.dana.com/pdf/X510-8DSD.pdf
610047-4 = Dana 44 / 3.50
Sounds like you're correct on the rearend being a Ford 9" / 3.50
16A:
16 = 1975/79 Ford 9" rear axle / 3750 lbs capacity / 3.50 open differential
A = With adjustable steering column and power steering.
D9TA AAA:
Dana ID no: 610047-4 / Dana 44-9F / 3.50 ratio / non free running hubs / non-locking differential / 3500 lbs capacity
WDM-C:
Complete code is WDM-CN. Uses 1330 joints. Matches the rear axle decoded in first paragraph.
D9TA AAA:
WDM-C:
randyein
10-08-2020 03:59 PM
Lex2002
07-14-2013 09:41 PM
