need info on dso codes
Old Aug 5, 2005 | 02:40 AM
randyein's Avatar
randyein
I have just purchased an 1981 ford f 150 custom 4x4 sb, and i am looking for as much info as possible
vin # 2FTEF14G2BCB02381
engine 351 c 2bbl
wb/ 117
gvw/ 142
body/ cu4
trans/ k
axle/ h6/cz
dso/ f0202/ ?0510/ 136
diffs
rear tags top row/ fe aw 1e07
rear tag bottom row/ ?L50 9 s31913
front tag top row/ 3.50 e?ta eg
front tag bottom row/ 610185-10
transfer case/ 13 45 039 904
if you have any knowledge of these codes please reply
picked this truck up for $300 can
needs new box has a little cancer on driver side floor nothing that can't be fixed.
no other problems runs great.
would like to restore.
thanx randy
Old Aug 5, 2005 | 11:58 AM
mblayton's Avatar
mblayton
In the bottom right corner of the tag where dso is listed there should be a double digit number beside the ones you listed F0202/0510/136 these are front axel accessory reserve and total accessory reserve in pounds. As far as your vin goes 2F name and location of manufacturer, TE is GVWR, 14 model line, G engine type, B model year, C assembly plant (in this case Ontario Truck where I worked) B sequential seirial no. Hope this helps a bit.
Old Aug 5, 2005 | 10:41 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
engine 351 c 2bbl
wb/ 117
gvw/ 142
body/ cu4
trans/ k
axle/ h6/cz
diffs
thanx randy
I think I can help you out...
Your Vin Decodes as follows.
2FTEF14G2BCB02381
2FT = Ford Motor Company of Canada Complete Vehicle
E = GVWR class and Brake System Class E, 6,001-7,000 pounds.
F14 = F-series / F-150 / 4x4 / regular cab pickup.
G = Engine 5.8 L - 351 V8 / gas / Ford
2 = check digit.
B = Year / 1981
C = Plant of manufacture Ontario Truck.
B02381 = production Sequence Number.
Other codes you have given me as follows...
Wheel Base 117 inches
GVW = F142 = 6050 Gross Vehicle Weight
Body = CU4 =
C = B/ Cloth and Vinyl bench seat.
U = Color Interior = Fawn
4 = Styleside pickup
Trans = K = Automatic C6
Axle = H6 = Limited Slip, capacity 3750 - ratio 3.50
Axle = C2 = Dana 61, Limited Slip, Capacity 5300, ratio 3.00
The above was decoded from the 1981 Light truck service manual. I could decode two more codes for you using this manual If I had them.
You are missing the D.S.O distric code. It should be a two digit code as 72 = San Jose California, or 48 = Detroit, etc..
You are also missing your paint ident code should be two digits or a digit and a number. Color Code 5G = Dark Caramel Metalic, or 5E = Light Fawn etc...
The From here on below is a guess on my part.
Your Front axle tag is showing the axle ratio 3.50 and what follows it looks like part of a part number or engineering number like E0TA-EG for example, and the 610185-10 could be a part of that number.
The other tags I have no clue. Sorry...
If you want the D.S.O. Distric order code, and the Paint code decoded, let me know.
Also of note, if you ask Ford Motor Company for a Build Sheet, you may be able to find out what was special ordered on your truck. Give them all of your information like you did here, and be sure to include the D.S.O distric code, and special order code in the D.S.O space.
Hope this helped you out.
Old Aug 6, 2005 | 09:14 PM
randyein's Avatar
randyein
thanx for all that info i will get back with the rest of the dso code later
Randy
Old Sep 25, 2020 | 07:25 AM
nreynolds's Avatar
nreynolds
Trailering
If you want the D.S.O. District order code, and the Paint code decoded, let me know.
Also of note, if you ask Ford Motor Company for a Build Sheet, you may be able to find out what was special ordered on your truck. Give them all of your information like you did here, and be sure to include the D.S.O district code, and special order code in the D.S.O space.
Hope this helped you out. [/QUOTE]
Talk about bringing up an old post! Anyway, do you have any idea what DSO #0099 would be? My 1996 was built at the Ontario plant on 12/6/1995 ordered by District 72. Seems odd to me. I appreciate your help.
Old Sep 25, 2020 | 09:39 AM
Franklin2's Avatar
Franklin2
These people have the original build sheet info for older Ford vehicles. I think the 1980 up trucks are included in that.
https://www.martiauto.com/index.cfm
Old Oct 4, 2020 | 10:00 PM
Rusty_S's Avatar
Rusty_S
They have two things, they have original build sheets for fords from the very late 60`s very early 70`s. The information how ever they can find for our trucks and even print out a reproduction window sticker for our trucks. Down side is they dont really have the ability to do much for Ford before the 60`s even though you can go back to the 50`s on their site. Its a shame in that aspect cause I wanted someone to make a reproduction of my original service policy/bill of sale for my '56 so I can put the reproduction in the glovebox with the reproduction paperwork I have and keep the originals locked up for safe keeping.
Old Oct 8, 2020 | 03:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1981 Thru Today
2nd line of Certification Label: At the left: EXTERIOR PAINT COLORS _____ .......................................... At the right: DSO _____
Binkowski
Feb 23, 2024 07:02 AM
Jason May
Dec 6, 2014 11:29 AM
Jam21
Mar 8, 2011 09:02 PM
Ron/RPMS
Dec 29, 2009 01:55 PM
eedbl
Apr 4, 2005 05:59 PM
