Oil & Lubrication
oil cooler on E150
Old Feb 10, 2001 | 09:24 AM
pr
oil cooler on E150
Anyone have experience adding an oil cooler to an E150 Ford van, 5.0L? The one I am looking at is a B&W cooler from carparts.com. Is there a noticeable improvement in engine cooling when towing? Also, I see there are options for fitting the screw on filter with adapter, just need enough clearance for removing filter since adapter is 1" thick.
pr Ford econoline Van, 5.0L 27' Jayco travel trailer
Old Feb 10, 2001 | 10:13 PM
stephenw's Avatar
stephenw
oil cooler on E150
Old Jul 13, 2003 | 06:50 PM
c_rossman's Avatar
c_rossman
oil cooler on E150
Adding a oil cooler will increase the life of the oil in hot climates and heavy towing. If you are in a colder climate it may make your oil run too cold and not boil off any condensation.
austinlibke
Nov 26, 2012 05:39 PM
pr
Mar 10, 2002 06:57 PM
pr
Mar 25, 2001 12:36 AM
pr
Mar 21, 2001 04:42 PM
pr
Computer Chips & Tuners
Jan 21, 2001 03:42 PM
