transmission deep pan
Old Mar 19, 2001 | 07:17 PM
pr
[font size="1" color="#FF0000"]LAST EDITED ON 19-Mar-01 AT 08:23 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 19-Mar-01 AT 08:22 PM (EST)[/font]
Are the transmission deep pans really worthwhile for transmission cooling? I have found a B&M deep pan that should fit my '92 E150, cost is around $150. So far haven't found other pans, such as derale or summit, listed as fitting this transmission, 4 spd Ford AOD. I was looking for extra capacity, and using synthetic fluid to run cooler. I already have tranny cooler (in radiator and separate cooler), but want to maximize protection while pulling a travel trailer in summer. Just wondering if $150 for deep pan plus synthetic fluid is worthwhile. I have tried the whitney, summitracing and carparts sites-only pan I see that fits is B&M.
pr, '92 E150, 5.0L
Old Mar 20, 2001 | 07:13 AM
DeenHylton's Avatar
DeenHylton
Sounds like over kill to me...if your really worried about it just add an additional tranny cooler or change your present one out for a bigger one. To put your mind at ease, add a tranny fluid temp gauge. Deen
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Mar 20, 2001 | 07:47 AM
oz9609's Avatar
oz9609
I agree with Deen. It is overkill. Install a trans temp gauge and modify the system accordingly. A $20 cooler will do more than just about anything to keep it cool. The gauge may show you that there is nothing else you need to do.
Old Mar 23, 2001 | 06:27 AM
pr
Thanks. The temp gage makes sense. Where is the temperature sensor normally mounted for tranny temp? Would I need to mount it on the pan, drill and tap?
pr, '92 e150, 5.0L
Old Mar 23, 2001 | 08:19 PM
CantDrive55's Avatar
CantDrive55
You'd be better off to spend your money on a good shift kit. It will take the slopiness out of the shifts, giving better shift firmness, which should extend the tranny's life. Transco and B&M both make kits for the AOD. price is probably under $150.
Old Mar 25, 2001 | 12:36 AM
rfitz's Avatar
rfitz
welder4life
Aug 10, 2001 03:30 AM
johnjohn
Mar 31, 2001 04:52 PM
390f100
Mar 12, 2001 10:53 PM
reddevilf150
Mar 9, 2001 10:37 PM
snizzitch
Oct 3, 2000 09:35 PM
