stripped window crank
Old Aug 8, 2009 | 01:03 PM
virtualm's Avatar
virtualm
The window crank is stripped on my '61' F100. Where can I get these parts? can't seem to find em in the catalogs for this year
Old Aug 8, 2009 | 01:30 PM
daveengelson's Avatar
daveengelson
If not seriously stripped may try taking a small fine triangular file and clean the grooves, it worked for on my 65, this was several years back and have not had any problems. Not aware of a replacement crank spindle. Tried salvaging a regulator by removing the crank from a donor regulator and attach to another with no success. Perhaps with a MIG, or TIG unit. With any luck FTE member may have one; otherwise, likely have to purchase the entire window regulator, 61-66.
Came across a left: http://cgi.ebay.com/ebaymotors/1961-...Q5fAccessories
Old Aug 8, 2009 | 02:06 PM
Bill W's Avatar
Bill W
What side do you need?
Old Aug 8, 2009 | 02:21 PM
virtualm's Avatar
virtualm
I need the driver's side shaft
Old Aug 8, 2009 | 02:43 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
virtualm
For a cure that would get you by for a while , you used to be able to get a ( Set Screw replacment
handle ) they would work real good for a while , how ever it may make it worse ,but keep an eye
on it ,because if the ( Set Screw ) works loose ," and it will " it leaves a circle a round the door
metal and paint ! Also check that you have the right (corect) handle ,and that its not as simple as a striped crappy handle !
P.S. you used to be able to find them in the ( '' HELP " ) section of auto parts stores !
but I would still be looking for that regulator !
Wally Womack
Last edited by Pro-Street/StateTK; Aug 8, 2009 at 02:48 PM. Reason: Watching my Ps and Qs
Old Aug 8, 2009 | 03:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
The shaft was not sold separately, it only was furnished with the window regulator.
C1TZ8123201B .. Left (Drivers Side) Window Regulator / Obsolete
Fits: 1961/66 F100/1100 // 1967/69: F/T800/1000 & N/NT500/1000.
BOYER FORD TRUCKS in Minneapolis MN has ONE = 800-999-4327.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675. This dealer wants big bucks for obsolete parts.
No other Ford Dealer or obsolete parts vendor has any.
virtualm's Avatar
virtualm
it's the spindle that's stripped but thanks for the info
Old Aug 8, 2009 | 03:09 PM
NumberDummy
Uh...the splined spindle shaft, the gears, whatever...were only furnished with the window regulator itself.
The only parts that did not come with the window regulator, were the window crank handle and the plastic window roller.
~ ~ ~ The crank handle's splines may also be stripped. ~ ~ ~
C1TZ8123342A .. Window Crank / Right/Left is the same / Obsolete
BOYER FORD TRUCKS has ONE = 800-999=4327.
GREEN SALES CO. in Cincinnati OH has THREE = 800-543-4959.
KLIMESH AUTO SALES in Calmar IA has FIVE = 563-562-3241.
MILLER OBSOLETE PARTS has TWO = 800-546-7278.
LAFOURCHE FORD L/M in Lockport LA has TWO = 800-375-5547.
KOVATCH FORD in Nesquehoning PA has FOUR.
BADAS03SVT
Jun 5, 2017 02:21 PM
darmento
Aug 2, 2016 03:07 PM
deezdrama
Aug 1, 2016 06:50 PM
Kaderpiller
Jun 10, 2016 04:53 PM
65f100Pit
Sep 7, 2015 01:01 AM
