So on my platinum under the windows on each side I have this chrome strip. My buddies Lariat does not have this or its black? Can these be swapped or mine just removed?
They can be swapped.
I just ordered the black F-150 moldings iirc.
With the door open you will see a small black torx screw. Remove it and start prying.
They can be saved depending in how you pull them off.
2 torx screws holding the outer belt molding. One on each end and 4 long clips that can break, holding it to the top of the outer door.
the mirror does not need to be removed just lift the molding up after you unclip it and slide it back. Just make sure it won't rub on the exterior door paint, the belt molding ends can scratch. Sometimes the front moldings bend and become damaged since they are long and the clips hold it down.
i have seen a couple posts on the facebook 2017 sd forum that state the mirrors need to be removed to get the front off
