removed my lower cladding
Old Dec 19, 2014 | 06:45 PM
  #121
Apocalypse's Avatar
Apocalypse
Yeah, please post up the pics. That sounds kind of odd and it'll be next to impossible to help you with that without the pictures. Might the an EB only thing?
Old Dec 19, 2014 | 10:32 PM
  #122
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
No, Excursions never had holes behind the cladding except right in the back.
if there are holes, they were done after it left the factory.
Old Oct 9, 2015 | 06:28 AM
  #123
pennsylvaniabo's Avatar
pennsylvaniabo
Originally Posted by dzldenny
The first pic is with the corner cut out. You can see how bad the inner was and this isn't even the bad part.
The second is the cab corner we diced up to fit.
The third is the corner in and paited.
is that a crew cab, or ext cab, cab corner that you used?
Old Oct 21, 2015 | 01:56 PM
  #124
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Some nice, new pics to add to this great thread. My passenger front door cladding was peeling off. Previous owner was in a crash at some point, and the repairs were not done very well. Paint job has flaws, and the cladding was not applied correctly back on the X. So, I removed it. Was a pain in the butt to get all the extra wide double sided tape off the door. Found a half-*** paint job underneath the cladding. Decided I was going to remove ALL the cladding. Got this far:
...and the wife and I are really liking how it looks like this! I may just stop right here and leave it this way.
Old Oct 22, 2015 | 09:03 AM
  #125
Alex F's Avatar
Alex F
I have the tan cladding on a black XLT and I hate it. I'm glad to see that it's fairly easy to remove, other than the glue residue, I guess?
Old Oct 22, 2015 | 09:28 AM
  #126
Drunken_Unicorn's Avatar
Drunken_Unicorn
The glue adds flair.
Old Oct 22, 2015 | 11:35 AM
  #127
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The glue is actually double sided tape. It is tough to get off by hand. I bought a "magic wheel" for my drill (made by 3M). I will use it on the driver's side and see how much faster it goes. Removing the two door panels on the passenger side took me about 4 hours of work. I tried every solvent/remover that they make for car applications (and spent $$$ on them), but none of them impressed me. Goo gone worked best I think, but it does not soak into the tape very quickly, and you have to re-apply it often as you are working the tape off.
The panel that was already peeling was easy to get off. The panel that was still properly affixed to its door was a lot harder. I used a wide chisel and a small scrap of wood to pry against. This enabled me to get one corner started, and then I used my hands to pull it off the rest of the way. You just have to pull evenly across the piece and work it off. I was trying to get mine off undamaged. If you don't care, it will go quicker.
Old Oct 22, 2015 | 02:11 PM
  #128
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
LOL this is still going, I love it!
Old Oct 22, 2015 | 03:19 PM
  #129
Apocalypse's Avatar
Apocalypse
Nate, you have 2 accounts?!?
Old Oct 22, 2015 | 03:36 PM
  #130
Alex F's Avatar
Alex F
I don't plan on putting it back on, so it's ok if everything but the truck paint is damaged in the removal!
Old Oct 22, 2015 | 04:34 PM
  #131
LivingLarge's Avatar
LivingLarge
I still don't get this mod...
Old Oct 22, 2015 | 05:41 PM
  #132
dzldenny's Avatar
dzldenny
Going off of memory here and it was a few years already but if I remember right, it was a regular cab corner. Though a CC rear should also work. Same? We cut away the outside section and only used the inside that gets hidden when the door closes anyway. Can't say on the extended because I've never had one to look at.
Old Oct 22, 2015 | 11:31 PM
  #133
RBerry9511's Avatar
RBerry9511
I was just wondering has anyone tried using a heat gun to remove the adhesive residue? I haven't removed my cladding yet but hope to in the next few months . The heat gun seems like it would make the job easier and quicker. I could be wrong but let me know if anyone has tried it. Those 3m wheels can get costy......and I am cheap because I have to be........lol.
Old Oct 22, 2015 | 11:39 PM
  #134
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes, I tried the heat gun on settings from 300 deg to 600 deg. It made the glue stickier and harder to get off. It wanted to smear rather than come off. The colder/harder the glue is, the easier it is to get off in larger pieces.
Old Feb 18, 2017 | 02:39 PM
  #135
kynobi's Avatar
kynobi
keep this post alive in 2017
Howdy all
I have an 04 xlt in the blue metalic with grey cladding and much like the original poster, my voyage begins with loose passengerr door cladding. I am thinking of taking all the cladding but the rear tires off and then painting those rear panel to match. Any one tried that approach?
