removed my lower cladding
Old Aug 13, 2009 | 07:00 PM
ex2k's Avatar
ex2k
My truck has the trim over the wheel wells as well, does anyone know if there are there holes in the body from mounting this or is it just held on with adhesive? I want to take it off...really bad!
It looks like this (not my truck): <img src="http://www.americancarsuk.com/Ford_Excursion_W622SBF/Ford_Excursion_Limited_000DSCF0063.JPG"
Old Aug 13, 2009 | 08:21 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
there should not be any holes behind the eb/limited trim. i believe it was all held on with adheasive and the screws on the underside of the fender lips.
i got my stone gaurds today and installed, them..looks much better i will be painting them to match here soon once i get my parts for my frontend(small wreck) but for now it looks much better then holes in the body.
the paint underneath was not any different then the paint above, just no swirl marks lol but a good waxing and alittle buffing before that made it match almost perfect.
Old Aug 14, 2009 | 12:30 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
the pics
before
after
Old Aug 14, 2009 | 09:08 AM
BostonX73's Avatar
BostonX73
very nice!
Old Aug 14, 2009 | 01:43 PM
fatswany's Avatar
fatswany
Looks sharp.......hmmmm.
Old Aug 21, 2009 | 10:19 PM
Excursioncamp's Avatar
Excursioncamp
This is an excellent and easy project. I just did this over the last two evenings on my 2002 aspen green excursion. It looks much cleaner, and with my black 20x10 kmc xd rockstar wheels and 37" Nittos, then entire rig looks great.
Removing the two sided tape didn't take that much work. I used goo-gone and a little elbow grease. The paint underneath looks no different than the rest of the truck as I've kept it very well waxed, even after never being garage kept for its entire life. I like the change in its look.
Old Aug 21, 2009 | 10:22 PM
Excursioncamp
Also, thanks for the link to the Ford site and suggestion for the rock guards. I just ordered a pair. Thanks to everyone who provides ideas, links, and advice. I find this site very valuable.
Old Aug 21, 2009 | 11:13 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
you should post some pictures! i'm glad your happy with it. its not a hard project at all and it makes a hell of a differance.
Old Aug 23, 2009 | 08:37 AM
Excursioncamp
...soon as I have enough posts, I'll be glad to add pictures...
Excursioncamp
Will try soon - thanks.
Old Aug 23, 2009 | 03:37 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
soooo....you simply PULL on the top edge of the plastic to get the cladding off?
Old Aug 23, 2009 | 05:21 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
on the doors yes, just find an edge and pull. but on the front fender and the rear QT panal there are plastic push pins and bolts that need to be removed first before pulling on them.
Old Aug 23, 2009 | 06:57 PM
  #28
jdadamsjr's Avatar
jdadamsjr
DANG YOU TWO !!!!!!!!!!!!!!
My wife was looking over my shoulder and now I have to do it too
it actually looks reversible with some double sided tape !!!!
Old Aug 23, 2009 | 11:08 PM
  #29
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
yes very much so, anytime you want to you can re-install it with some double sided tape and alittle time.
Old Aug 24, 2009 | 08:43 PM
  #30
reddnoze's Avatar
reddnoze
my X is black and had gold lower cladding & wheel well trim i painted it black with spray cans , it looks really good now after reading this thread im kickin myself.. now gonna take it all off
