Sponsored by: Real Truck
ABS Brake Disconnect ?
Old Mar 22, 2012 | 12:07 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The green color is because of the copper in the lines corroding from moisture in the brake fluid. Mine was slightly green when I did it a few months ago.
It's really not a big deal, it's good that you caught it now. In my case, I had a severe pull to the left, and it turned out the right front brake hose was clogged with crud, most likely the hose was coming apart. So I changed them on both sides and fully bled everything including the backs.
Old Jan 31, 2020 | 06:06 PM
DanielLefebre's Avatar
DanielLefebre
I have to replace my abs hydraulic control module. Does this mean after i install the new one I am forced to go to the dealership to bleed it?
Old Feb 1, 2020 | 12:39 PM
krewat's Avatar
krewat
No, but you have to have it bled by a mechanic who has certain diagnostic tools to perform the bleed cycle.
Or, Forscan might work for that.
bazzman1953
1983 - 2012 Ranger & B-Series
Aug 29, 2019 03:37 PM
jaybob1807
Feb 28, 2014 03:48 PM
steedinthesky
1997 - 2003 F150
May 23, 2007 02:32 PM
Whitebassist
Aug 28, 2002 10:34 AM
