Quick question
Old Jul 25, 2009 | 12:52 PM
  #61
FordNFishinLover's Avatar
FordNFishinLover
I washed all parts with dawn soap and water and let air dry before painting.
I think i found a cure! I let it sit out for 3-4 hours in the hot sun on top of our garage yesterday. Its "slowly" getting more dry. Its not NEARLY as bad as it was. So im gunna let it sit out for a few days to let it really cure and it will hopefully be fine here soon.
If not im gunna have to try something eles, and thank you very very much for yalls suggestions!
Old Jul 25, 2009 | 12:57 PM
  #62
FordNFishinLover
Had all the gauges painted and what not, put it in last night cause i was heading out to friends house.
They look fantastic! Very very bright and easy to read. BUT my freaking fuel gauge is not working now!!!!
What are some causes that could keep this from working? i tried cleaning around the areas of the circuit board on the back. An loosened the nuts alittle on back, and still nothing.
Any help is very thanked.
Old Jul 25, 2009 | 01:16 PM
  #63
ctubutis's Avatar
ctubutis
Did you perhaps get paint inside of it and the mechanism is stuck together? That
needle assembly is exceedingly delicate....
Old Jul 25, 2009 | 01:43 PM
  #64
FordNFishinLover
Very possible.... how would i free it?
Move the needle around by hand some or what?
Old Jul 25, 2009 | 01:53 PM
  #65
ctubutis's Avatar
ctubutis
I have no idea but I'd be inclined to try acetone to wash the paint away. Just to
rule out another possibility, I'd first remove the wire from the tank sender and
ground it, the needle should swing all the way in one direction; un-grounding it
should make it swing the other way. Might check for the presence of voltage, too.
But, the likely culprit is something that recently changed, most likely something
in the gauge itself....
Old Jul 25, 2009 | 02:26 PM
  #66
FordNFishinLover
Okay im pretty sure i found the problem.
I took apart the gauge and i found that the little wire that runs from each side has come unglued on a side. So im gunna glue this, but now im not sure how the needle goes back onto the gauge....lol Any help on how to put it on? Thanks
Old Jul 25, 2009 | 03:33 PM
  #67
81-F-150-Explorer's Avatar
81-F-150-Explorer
I'd get another gauge. That one most likely won't work now.
Old Jul 25, 2009 | 04:10 PM
  #68
FordNFishinLover
How is that? As long as i get the wire back on and needle in place i think it should work?
Can anyone help me out on this needle? Its keeping me from putting my dash back together right now.
Old Jul 25, 2009 | 05:37 PM
  #69
81-F-150-Explorer
Perhaps I should have added, work correctly. The gauges are not meant to be taken apart like that, and they are a loosely calibrated instrument. It's possible that the gauge might read 1/8 full and your tank be empty, or not work correctly now.
I personally would get a used gauge in the wrecking yard. Should be around $10 for the gauge. $35 for a whole cluster. The wrecking yard I frequent will even warrantee the part if it's brought back within a week.
I'm afraid I can't help with the needle.
Old Jul 25, 2009 | 06:45 PM
  #70
FordNFishinLover
Oh okay. Thank you very much.
Nearest junkyard round here is 1/2 hour away and i have no money right now so lol.
If anyone has a instrument cluster out of their truck could they please look at the fuel gauge and tell me how the needle is put on? This is keep me from putting the dash together right now so i gotta figure it out! Thank you!
Old Jul 25, 2009 | 07:23 PM
  #71
ctubutis's Avatar
ctubutis
Gimme a few minutes, I'll add URLs to this post....
EDIT: Except for the ammeter, they're all the same gauges inside.
I have never tried to remove a needle; as 81-F-150-Explorer said, these are somewhat-
calibrated instruments and are quite delicate.
Besides, look at those TINY wires! My eyes aren;t that good anymore + I don't know
where my tweezers are....
-ct
http://img193.imageshack.us/img193/70/p1010192g.jpg
http://img193.imageshack.us/img193/3852/p1010191u.jpg
http://img406.imageshack.us/img406/3161/p1010190q.jpg
http://img406.imageshack.us/img406/3562/p1010189x.jpg
http://img406.imageshack.us/img406/263/p1010188.jpg
http://img406.imageshack.us/img406/4451/p1010187k.jpg
Old Jul 26, 2009 | 02:14 AM
  #72
FordNFishinLover
Ctubutis, you went over and beyond! Thank you very much for the help.
I figured out how it went on, and found that i bent a peice of the metal also. Of course when i was fiddling with the needle i broke it also hahaha.
So now i gotta find a new gauge anyhow.
Again thank you very much.
On the other note i got some other work done to the truck. I got everything ripped out to the floor today. Than i cleaned the cab real good, (got all the loose paint and grim and ect..) and sprayed everything with rubberized under coating with sound eliminator.
Old Jul 26, 2009 | 09:14 AM
  #73
ctubutis's Avatar
ctubutis
No prob! I have these things already taken apart as I experiment around with the
paint-your-gauges stuff, all I had to do was take pix & post 'em.
Did anybody mention anywhere that these things are delicate? Heh....
-ct
Old Jul 26, 2009 | 10:57 AM
  #74
FordNFishinLover
lol theres no dought there no them being delicate now.
Picked up some carpet padding to use under my rubber floor mat to help with sound and insulation. So im gunna form that to the floor today,fix my rubber mat, and get my bench in. Hopefully lol
Im hoping this carpet padding works good. I dont think it could hurt. Also it was free
Old Jul 26, 2009 | 01:21 PM
  #75
girlwithatruck's Avatar
girlwithatruck
rubberized coating
dude! once again i'm so glad you're a couple of steps ahead of me! I just hit all the scraped up spots on my floor with rustoleum just so there's no exposed metal but that is a GREAT idea with the rubberized sound deadener you sprayed on. What product did you use?
Since i had to drive up to Sacramento yesterday to pull a fender i'm a couple days furtehr behind now. (Was gonna try to get my seat in today too) But adding the sound deadener might be a step worth losing another day for.
