Sponsored by: Real Truck
No overload spring
Old Jul 12, 2009 | 06:18 AM
Bear 1's Avatar
Bear 1
No overload spring
Vin # 1FTNW21P24ED51285
o4 cc 4x4 SD srw SB. Can any one tell why this truck has no overload springs? And what isthe GVWR? Thanks for your help. I havn't posted in the wrong place. I am not real puter savey.
Old Jul 12, 2009 | 06:26 AM
scraprat's Avatar
scraprat
Top Answer: 5
Depends on the package it was order with(camper,plow etc.) I believe the 250 is 8800# and the 350 is 9900#.
Old Jul 12, 2009 | 06:55 AM
Bear 1's Avatar
Bear 1
Sorry bout that it is a f250.
Old Jul 12, 2009 | 04:07 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The GVWR should be listed on the tag on the b-pillar of the cab, right there with the VIN, axle and spring info, etc.
Old Jul 12, 2009 | 05:33 PM
powerstroke72's Avatar
powerstroke72
Here's a link to the '04 order guide for the '04 F-250. It appears like other years in that the overloads come as part of the camper package.
http://www.sunrisefordfleet.com/pdf_...er%20Guide.pdf
From the order guide:
CAMPER PACKAGE (532)
• Heavy service front springs (200 lbs. Upgrade above the
spring computer selected as a consequence of options chosen.
Not included if maximum springs have been computer selected
as standard equipment)
• Rear stabilizer bar
• Slide-in camper certification
• Auxiliary springs
NOTE: Salesperson's Source Book or Ford RV Trailer
Towing Guide should be consulted for specific trailer towing
or camper limits and corresponding required equipment, axle
ratios and model availability.
Old Jul 12, 2009 | 06:21 PM
aldridgec's Avatar
aldridgec
From the VIN, you have a crew cab F250 4x4 6.0L PSD. In 04 they were all 8800lb GVW. As others have noted, unless it had a special package, it did not come with the auxiliary spring (the one on top). Spring codes from door won't tell you if it did or not.
Old Jul 13, 2009 | 04:46 AM
Bear 1's Avatar
Bear 1
Smile Thanks Aldridgec
Thanks for looking that up, I thought they just got left off. Because most others I have looked at have them. Again Thanks.....
Old Jul 13, 2009 | 04:51 AM
Bear 1's Avatar
Bear 1
Thanks guys. For all your responses.
Old Jul 13, 2009 | 08:46 AM
brian42's Avatar
brian42
Veteran: Navy
the overload spring comes stock on all F-350's, but is an option for the F-250's for our body style (99-04).
GVWR 8800lbs like everybody else said....
Old Jul 13, 2009 | 11:19 AM
GregsSD's Avatar
GregsSD
Same on the 05's also, I did not order the camper package so my 05 has no overload springpack.
I use my F-250 for pulling trailers and use the Firestone airbags as adjustable overloads.
Old Jul 14, 2009 | 04:42 AM
Bear 1's Avatar
Bear 1
Air bags
I was wondering if those would work,just as well. Thanks.
Old Jul 14, 2009 | 10:41 AM
GregsSD's Avatar
GregsSD
They work great, you just put in the amount of air that you need depending on how much weight you are hauling so your truck doesn't squat low in the rear.
Old Jul 14, 2009 | 10:57 AM
scram98400jm's Avatar
scram98400jm
Scraprat-Curious what the difference is between the F250 & F350 to allow the 8800 vs 9900 GVW difference? Mine is 8800 & my friends is 9900 just as you say & both are single rear wheel & look exactly the same from what I can tell?
BTW- I installed the Timbkin rubber overload bumper thing that looks like air bags but isn't & it works great & it was really cheap. I have the camper pacakge w/ the overload spring which I was supposed to remove but I left it on w/ the Tmbkin's & it works fantastic. I can load it really heavy & it doesn't sag at all.
Thanks
Old Jul 14, 2009 | 11:00 AM
Ace!'s Avatar
Ace!
It's likely the size of the block under the rear leaf springs. The F350 gets an overload as stock and the F250 gets one as part of a suspension package (camper, heavy service, plow). All of this can be dependent on year.
Old Jul 14, 2009 | 11:30 AM
superduty4x4's Avatar
superduty4x4
How is the block going go to change GVWR? F350's get a bit more spring in the rear than the 250's.
