Sponsored by: Real Truck
No overload spring
Old Jul 14, 2009 | 01:49 PM
  #31
GregsSD's Avatar
GregsSD
[quote=Ace!;7717473]My 2005 F250 GVWR is 9600. I just walked out and checked the door jamb.
quote]
I just checked, and my 2005 F-250 GVWR is 10,000. But mine is a diesel.
Old Jul 14, 2009 | 01:51 PM
  #32
brian42's Avatar
brian42
Veteran: Navy
They definitely made a suspension improvement in '05, because I'm only good for 8800lbs...
Old Jul 14, 2009 | 09:11 PM
  #33
Ace!'s Avatar
Ace!
Yep, 2005 F250 4x4, CC, SB
5.4L: 9400 GVWR; Payload: 2700
6.8L: 9600 GVWR; Payload: 2800
6.0L: 10000 GVWR; Payload: 2700
Old Jul 14, 2009 | 09:31 PM
  #34
powerstroke72's Avatar
powerstroke72
You know, this is interesting too. I looked at the tire inflation sitcker on the "B" pillar on my truck and it says the actual payload should not exceed 2210 pounds. And this is with the 275/70-18E tires. They had a huge thread in this in the 2009 F-150 forum where some of the guys with 2009 Platinum F-150s were seeing 750 pound payloads on these stickers.
Old Jul 14, 2009 | 10:08 PM
  #35
Ace!'s Avatar
Ace!
Well, GVWR and payload are relative to the people and options of the truck. The Lariat will likely have more options than a base truck, then the diesel lowers payload a little too. Least that's my guess.
Old Jul 14, 2009 | 10:11 PM
  #36
powerstroke72
Yeah and I agree. The same questions were posed in that F-150 thread and I agree with those guys in that 750 pounds of available payload in an F-150 is ridiculous. Some were saying it is all based on the tires but my tires are rated at 3640 pounds each. Weird.
Old Jul 14, 2009 | 11:24 PM
  #37
superduty4x4's Avatar
superduty4x4
None of this nonsense can explain why my early 99 250, which came with factory 4" blocks, has a GVWR of 8800 lbs when the F350 got 9900 lbs in the same year with the same components...
Old Jul 14, 2009 | 11:30 PM
  #38
aldridgec's Avatar
aldridgec
Originally Posted by greenego
I still have the original window sticker for my 2001 F250 and it does not include any kind of an optional suspension package ( only the standard trailer towing package ) but there is an overload spring.
Did you buy it new, if not, then anything could have happened. If so, then not sure what to say as to why it has it. Technically it shouldn't.
Old Jul 14, 2009 | 11:36 PM
  #39
aldridgec's Avatar
aldridgec
Exactly....
Really, it's nonsense. nonsense we don't really deal with here in MD, but a lot of people in other states do in the form of taxes and registration. Really, the f250/f350 were basically identical for the longest time, with different Fed Certification labels. Same brakes, axles, tires, springs, coolers engines transmissions frames . After 05 they changed how the trucks were rated and you could get a 10,000 GVWR in an f250. Depended on a lot of options of course, but they made the trucks configure in a way that supported the GVW. Probably because it doesn't make sense to add an engine that xx lbs heavier, and more powerful and be able to haul less stuff. So in some sense there is science and engineering behind it, then on the other it is just marketing and sales.
You'll never get the technically right answer, or the marketing answer. It just is what it is on the door....
Old Jul 15, 2009 | 05:59 AM
  #40
greenego's Avatar
greenego
aldredgec: I purchased the vehicle new.
Old Jul 15, 2009 | 09:44 AM
  #41
brian42's Avatar
brian42
Veteran: Navy
The F350 rear block raises the vehicle so it can "squat" an extra two inches. The part numbers for the rear springs are the same between a F250 and F350. As an example, my F250 has the EXACT same rear suspension, same springs, same overload spring; however, it has a block under the rear spring that is approximately 2" shorter. F250 and F350 share the same springs.
I disagree, the F-250 came stock with code A rear springs (6084 lbs) while the F-350 (single rear wheel) came stock with code B rear springs (6830lbs). (thanks bdrummonds)
Add that to the additional 2" of squat from the taller block and you have increased payload an GVWR.
See my above statement.
Old Jul 15, 2009 | 09:53 AM
  #42
Ace!'s Avatar
Ace!
Originally Posted by aldridgec
Exactly....
Yep, the sticker is king!!!
I should have added to my GVWR and payload post for 2005 trucks, Ford lists the curb weight difference from a 5.4L gas engine to 6.8L V10 gas engine as about 100 - 125 lbs. From 6.8L V10 to 6.0L PSD is about 500 lbs. The payload is highest on the V10 gasser, same or higher for the 5.4L gasser than PSD and the towing is the same (between 6.8L) and PSD; however the GVWR is higher on the PSD. All suspension parts being the same. So, the GVWR is approximately 200 - 400 lbs higher for the diesel, the payload is roughly 200 lbs higher for the gasser(s), the diesel engine weighs 500 - 625 lbs more than the gas engine(s) and the springs holding up all of that are the same. So, that 10,000 GVWR truck has the least amount of payload. Trying to figure it all out can take a while
Old Jul 15, 2009 | 10:13 AM
  #43
superduty4x4
Brian you's da MAN! I knew I remembered seeing somewhere that the F350 had a tad beefier springs than the F250. Now here's a question for you- does the F350 B code spring have an OEM overload, or was it optional with a spring upgrade package?
Old Jul 15, 2009 | 10:21 AM
  #44
Ace!'s Avatar
Ace!
Interesting. I just called my local dealership and asked the parts department. He stated he needed the VIN of the vehicles, then he told me it would depend on a bunch of things like options, then he said it would depend on the axle 9.75 or 10.5. Once he got a little more frustrated with my questions he looked it up and said, "Hmm, the F250 and F350 have the same spring".
So, I dunno. The builders guide and my local Ford dealership show the same part for an F250 or an F350. I only asked them about model year 2005.
By the way, I believe the lower rating of the spring is without the overload and the higher is with. It's my understanding that, as an example in 2005, the springs are rated at 6100 and 7000; however, the difference is the overload spring, not the spring pack. Again, I'm using a 2005 SRW Super Duty as an example.
Old Jul 15, 2009 | 10:29 AM
  #45
brian42's Avatar
brian42
Veteran: Navy
I know that the overload spring was standard on all F-350s from my generation 99-03.
Interesting. I just called my local dealership and asked the parts department. He stated he needed the VIN of the vehicles, then he told me it would depend on a bunch of things like options, then he said it would depend on the axle 9.75 or 10.5. Once he got a little more frustrated with my additional questions he looked it up and said, "Hmm, the F250 and F350 have the same spring".
There was a huge suspension change in '05 so I don't know the 250/350 stack up with the new underpinnings. The info I have is for the pre-05's with the leaf springs up front.
