Sponsored by: Real Truck
No overload spring
Old Jul 23, 2009 | 09:45 PM
  #91
aldridgec's Avatar
aldridgec
Originally Posted by Ace!
Yeah, it's just the booster as far as I know. The different booster is gas/diesel, but doesn't have anything to do with F250/F350, they are otherwise the same.
Yes but your response to the comment was in reference to capacity. So saying the difference is between gas and diesel would have implied that there was a different capacity between gas and diesel, not simply stating that there was a physical difference between gas and diesel as far as configuration.
and there it is #7
Old Jul 23, 2009 | 09:47 PM
  #92
aldridgec's Avatar
aldridgec
Originally Posted by Classic F-250
Hey guys my 2005 F350 Rc V10 4wd has a 10500 gvw. on the door sticker, I also believe the 18" wheels up the GVW......
The "rules" that we are debating only really apply to the 99-04 trucks. There were more differences starting in 05.
Old Jul 23, 2009 | 10:24 PM
  #93
Classic F-250's Avatar
Classic F-250
gvw's
Hey guys,
My 2005 Reg Cab F350 V10 4wd has a 10700 gvw.
(Ordered 9-2004) and has a overload spring.
It has a Camper Pkg., Snow Plow prep., and Payload Pkg.
I also believe the 18" wheels up the Payload capacity......
Last edited by Classic F-250; Jul 23, 2009 at 10:36 PM. Reason: double post.... and didnt se 99-04
Old Jul 23, 2009 | 10:57 PM
  #94
Ace!'s Avatar
Ace!
and there it is #7
My post was in reference to the model of truck, and that there isn't a difference between F250 and F350. The post I was to which I was respoding is: "Originally Posted by bayou barataria
I would like to stir it up some more and ask if the brake systems on the 250 and 350 are the same capacity?"
I think the different booster may change the brakes in a capacity sense, but maybe it doesn't, and it would be negligible anyway. The difference in the brakes is not between F250 and F350, but a difference between gas or diesel. That's all I was trying to say.
So, the answer is yes and no. The difference is between diesel or gas, not F250 or F350.
Old Jul 24, 2009 | 09:27 AM
  #95
brian42's Avatar
brian42
Veteran: Navy
I would say you have the camper package then. ALthough the camper pkg is supposed to give you an upgrade over the standard computer selected spring. But now I can't remember where the V rates in the spring chart. be back later with an answer, maybe.
I have the tow prep package and no camper package. The V code springs are for the front, rated at 5200lbs, and are standard on the diesel trucks.
Old Jul 24, 2009 | 11:41 AM
  #96
ruschejj's Avatar
ruschejj
Bayou, the "wig-wag" strobes are just xenon strobe lights at the four corners of the truck. Just like the various DOT construction trucks have.
Mine are installed in the front headlamps and in the clear reverse light lens in the rear. They are very cool. I use them because I work at hospitals all over the place and sometimes I need to take up the whole road maneuvering my trailer wherever they decide to park me.
They are also fun to cruise the neighborhood at night.
Old Jul 24, 2009 | 08:48 PM
  #97
aldridgec's Avatar
aldridgec
Well it sounds like you and I have the same setup. YOu have the truck since new??
I always understood the camper package was the only way to get the rear sway bar and the auxiliary spring.
I thought the "towing package" was standard on the SD trucks for most years (towing package did not include a "Built ford tough trailer hitch"), so the tow pkg wouldn't imply it included sway bar and aux springs. So how are we getting the rear sway bar and aux spring?
Old Jul 27, 2009 | 11:31 AM
  #98
brian42's Avatar
brian42
Veteran: Navy
Don't know. I bought the truck used 2 years ago but I requested the build sheet from Ford. No camper package, but I have a rear sway bar and aux springs. I'm not complaining!
Old Jul 27, 2009 | 01:46 PM
  #99
greenego's Avatar
greenego
2wd (250 or 350 afaik) shouldn't have any block under the spring, 250 most years has 2 inch block, 350 has approximately 4inch block.
If there are no blocks under the springs of the 2wd drive models then what gives the f350 more hauling capacity than the f250? The f350, I would think, has to have a different spring in order to give it more capacity but it has been mentioned on here several times that the f250 and f350 use the same rear springs but use different blocks on the 4wd models.
Old Jul 27, 2009 | 02:20 PM
  #100
wizardsr's Avatar
wizardsr
I just hauled 2.5 tons of gravel in the back of my F250, a job I usually reserve for the F350, but didn't feel like unloading the bobcat and unhooking the trailer from it. The 250 is a 2001, and it has the overloads in the rear. I'm not the original owner, so I dont know what criteria was used to get the aux springs, but is has the 6084 rear spring rating, and 4800 front (ext cab short box). Unloaded across the scales with only me in it was 6640, across the scales loaded was 11660, needless to say, the rear bumper was not far from the ground, but she handled it well, 70 on the highway with little sway. I'll be considering the taller blocks for this truck though, as the extra 2" would have helped keep the rear at a more reasonable height. The F350 on the other hand with 2.5 tons, the overloads barely touch, but that truck has airbags too, and I believe the rear springs are rated at 6800 something... I've had that truck to almost 13k (crew cab SRW short box). Psst, no telling MNDOT 'kay...
sgip2000
Apr 6, 2015 02:13 PM
theblackpassat
19
Oct 29, 2013 07:53 PM
Crewcab Turbo
Feb 3, 2012 02:01 PM
FORDF250HDXLT
Dec 23, 2009 04:32 PM
knuter_63
Apr 3, 2009 09:36 AM
