Sponsored by: Real Truck
No overload spring
Old Jul 20, 2009 | 10:55 AM
  #76
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by aldridgec
Do you have a rear sway bar? I have VA (iirc) and I have the camper package AFAIK.
Front and rear sway bars...
Old Jul 22, 2009 | 01:38 PM
  #77
brian42's Avatar
brian42
Veteran: Navy
Not to beat a dead horse, but I was looking at the technical specs from Ford (I don't know how to post the file here), but it looks like the springs are the 6830lbs springs for both 250 and 350, but the GAWR (gross axle weight rating) for the 250 is 6084lbs, while the 350 is 6830lbs. Thus the GVWR of 8800lbs for the 250 and 9900lbs for the 350.
There is no explanation why the GAWR is different since they are both the same Sterling 10.50 (comparison is based using 7.3L diesel single rear wheel 4x4), except the following note:
Gross Axle Weight Rating is determined by the rated capacity of the minimum component of the axle system (axle, computer selected springs, wheels, tires) of a specific vehicle. Front and rear GAWR’s will, in all cases, sum to a number equal to or
greater than the GVWR for the particular vehicle. Maximum loaded vehicle (including passengers, equipment and payload)
cannot exceed the GVW rating or GAWR (front or rear).
I don't what is weaker component in the 250, but with everything being the same, maybe it is the extra 2" squat from the taller block.
I also came across this note too:
Auxiliary rear spring will be removed as standard with 5.4L engine applications and will be included with certain option packages
(Effective Nov. 2002).
The file I have is only an excerpt from the tech specs. I don't remember which Ford document I got this from.
I know we've taken this farther than it should have ever gotten, but thought I would share some actual Ford info...
Old Jul 22, 2009 | 09:15 PM
  #78
Ace!'s Avatar
Ace!
Let's keep it going!!! Yes, again, it's the 2" squat from the taller block. Let see if we can get this to 7 pages!!! YES!!!!
Old Jul 22, 2009 | 09:38 PM
  #79
aldridgec's Avatar
aldridgec
So we are supposed to believe that by allowing the spring to arch around a taller block, so that effectively the suspension can squat 2 more inches without looking lower than the front, adds capacity.
Old Jul 22, 2009 | 09:52 PM
  #80
Ace!'s Avatar
Ace!
Absolutely, without question, unequivocably. Yes, yes, a thousand times, yes!
Old Jul 22, 2009 | 10:11 PM
  #81
bayou barataria's Avatar
bayou barataria
I would like to stir it up some more and ask if the brake systems on the 250 and 350 are the same capacity?
Old Jul 23, 2009 | 06:57 AM
  #82
aldridgec's Avatar
aldridgec
Supposedly on the older ones. The pads, rotors, calipers etc all appear to be the same.
Old Jul 23, 2009 | 11:30 AM
  #83
Ace!'s Avatar
Ace!
The difference is between diesel or gas, not F250 or F350.
Old Jul 23, 2009 | 05:25 PM
  #84
spinella's Avatar
spinella
look in the tech folder at the top of the superduty forum. it gives a good explanation on the springs.
Old Jul 23, 2009 | 05:39 PM
  #85
aldridgec's Avatar
aldridgec
Really?!
I'm showing the same part numbers for the hardware at the wheels. The booster is different though but I don't really think that add's any capacity.
Old Jul 23, 2009 | 05:41 PM
  #86
aldridgec's Avatar
aldridgec
I would say you have the camper package then. ALthough the camper pkg is supposed to give you an upgrade over the standard computer selected spring. But now I can't remember where the V rates in the spring chart. be back later with an answer, maybe.
Old Jul 23, 2009 | 05:57 PM
  #87
ruschejj's Avatar
ruschejj
This has been fun.
All I can say is, my 250 handles more weight and is more stable than any Chev or GMC 3500 I ever drove. I was nervous going to SRW but this truck is just unreal. I had to add airbags because of the sag when towing heavy, now it's just a monster. If a 350 is better, I hope I don't ever drive one 'cause I'll have to buy it.
Old Jul 23, 2009 | 06:04 PM
  #88
Ace!'s Avatar
Ace!
Really?!
Yeah, it's just the booster as far as I know. The different booster is gas/diesel, but doesn't have anything to do with F250/F350, they are otherwise the same.
Old Jul 23, 2009 | 08:21 PM
  #89
bayou barataria
Ruschejj, what is a "wig-wag" strobe light?
Old Jul 23, 2009 | 09:37 PM
  #90
Classic F-250's Avatar
Classic F-250
gvw's
Hey guys my 2005 F350 Rc V10 4wd has a 10700 gvw. on the door sticker, I also believe the 18" wheels up the GVW......
