Which Turbo?
...The 88mm GT compressor wheel provides 33% more flow than the stock 80mm wheel. The 88mm GT compressor wheel provides 33% more flow than the stock 80mm wheel...
For a given BP and MAT you get the same MAF airflow into the engine with any turbo including the stock GTP38!
For a given compressor wheel rpm an 88 mm compressor wheel generates more CFM volume airflow into the turbo inlet than you get with a stock 80 mm compressor wheel spinning at that same rpm but if the stock 80 mm compressor wheel spins at a higher rpm it generates the same turbo inlet CFM volume airflow as a turbo with a larger compressor wheel does spinning at a lower rpm and in both cases you get the same BP in the engine's intake manifold and therefore the same MAF airflow into the engine!
Of course if you look at the compressor map for a stock turbo you'll see it has a limit for its maximum compressor wheel rpm and this limits the BP to a maximum of about 28 psi and I know from experience that if it's frequently operated at 25 to 28 psi BP a stock turbo will only last about 50K miles!
On the other hand if occasional bursts of 25 to 28 psi BP is all you need then a stock turbo might last for 75K to 100K or more and you can buy two or three rebuilt stock turbos for the price of a GTP38R!
Also it's increased fuel flow that makes HP and increasing the airflow without the additional fuel flow actually reduces HP because when that extra airflow is compressed the compression stroke pumping loss increases!
These all look the same to me. Even the description on many of them are nearly identical. The one from BD comes with a .84 turbine housing, while most others are selling it with the 1.0.
http://www.puredieselpower.com/catal...roke-p-97.html
http://www.htturbo.com/ford.htm
http://www.gillettdiesel.com/gdsballbusterturbokit.aspx
http://www.gdsdieselparts.com/late_99-03_ps_turbos.htm
The only discrepancy I've noticed is how they size the compressor wheel in their advertisements for some of these turbos. From what I've seen they all use the same compressor housing and the same T-61 compressor wheel.
Modded H2e, IMHO (after running ALL the turbos mentioned in this thread for 30-40-50k) there is no better, tougher, cheaper, turbo out there. The thing is bullet proof, spools great, runs cooler then the 38r on my truck, loves boost, it quieter then the 38r and NEVER surges, stalls, chirps or talks back.
Are you saying that the new turbo with my existing Tuner and Exhaust will NOT give me any more boost then I have now with a stock turbo?
I have been told that the Smaller housing on the BD (and others) will not help decrease my exhaust gas temps, only helps the turbo spin up sooner.
Right now, I peak my PSI (with the stocker) @ about 25ish (give or take). My turbo starts to come alive @ about 1700-2000 RPM. What difference would I see here by changing turbos?
In my higher tunes, I push TONNES of black smoke (which tells me that I am wasting power, and I assume that more are or a bigger turbo to make more air, will compensate for)
From what I have gathered from the FAR too technical of a conversation, is that the Garrett BB turbo is the way to go for only a few $$ more for the following reasons:
Decreased EGT's as a result of the larger housing
Quicker Spool up as a result of the ball bearings
Longer life as a result of ball bearings
More potential for future mods
Are these assumptions accurate?
That is precisely why so many in this thread are recommending a GTP 38R. I know you claim to use a higher quality thrust bearing in your turbos but to suggest someone run over 25 psi on a stocker long term is reckless.
The OP has stated that he plans to go bigger on injectors in the future. An adjustable wastegate on a stock turbo with bigger sticks is asking for turbo failure.
The OP is not running enough now to get 35 PSI and reckless is too strong of a word for 30PSI.
With either drop-in turbo you're looking at, you'll be getting more air to the motor than stock because of the larger compressor wheels. I don't know if you'll see more boost, but it'll clean your smoke up considerably.
A larger exhaust housing will allow the exhaust to flow better and not build back pressure. BUT, a larger housing will be a bit laggier on the bottom end for the same reasons. Smaller housings like the stock turbo or drop-ins with equivilant exhaust housings will spool great, but will yield higher etgs.
Probably not much on the "coming alive". On the higher end maybe. Boost might increase slightly depending on what the wastegate on the aftermarket turbo is set at. With the "van turbo and ported compressor housing" that I run - stock injectors and a DP Tuner I never got more than 33 psi on the highest setting. Now with same turbo, stage 2 SS injectors, and Cale's tunes my gauge pegs quickly at 35psi. I'm getting more, but don't know what because the gauge only goes to 35.
I've driven a truck that has the same injectors as me, dual hpop, and a modded h2e and he's putting down 525hp. Not exactly sure what times he's running in the 1/4 mile but I want to say high 12's. The highest boost he hit on the track the day before was 37.5psi and highest egt was 1250. It doesn't throw much smoke either because it's got a very good air/fuel ratio with that turbo/injector combo.
In my higher tunes, I push TONNES of black smoke (which tells me that I am wasting power, and I assume that more are or a bigger turbo to make more air, will compensate for) Read above ^
Just my $.02
Can you guys post some actual #s, compressor maps, real world tests? Help the guy make a decision that is going to benefit him towards his power goals and not just line your pockets.
The subject of how much HP you can get at a given EGT is complicated and I'll address it later but I've already posted many times about a mod that costs 0$ and takes all of 5 minutes to do and will lower your EGT by at least 100F at WOT!
