Sponsored by: Real Truck
Adding Cab lights?
Old Jul 1, 2009 | 10:26 AM
LadderDogV10's Avatar
LadderDogV10
Adding Cab lights?
Looking at adding cab lights to my 08 250, who has done this what is needed? Where is a good place to look for a light kit, also should i have the switch wired into the light switch or upfitter switches?
Old Jul 1, 2009 | 10:49 AM
Firefighter 1406's Avatar
Firefighter 1406
I would think that since the cab on the 08 is the same as the 99-07 it would be the same for a install. I bought my lights from ebay and they are OEM Ford parts. They cost me $97.00. Recon makes some nice aftermarkets a lot of the guys have used also. Keep in mind that there is a differnt harness for the lights if you have a overhead console or if you don't. Motoman has a write up on the install if you search it he will tell you the measurements. Here is a link for the ones I bought. It says to 07 but I would think the only difference would be the plug on the harness, you would have to cut it off and just wire it into the running lights on the passenger lick panel. If it won't work get a hold of Ed the parts guy at Y2Kfordparts.com, he would get you exactly what you need.
1. First link is the ebay lights I bought that I think will work.
2. Second is Y2Kfordparts.com (talk to ed)
3. Third is Motomans website for the install
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
http://www.y2kfordparts.com/
http://www.emotoman.com/f250/lights/f250lights.htm
Hopre this helps you. Seth
Old Jul 1, 2009 | 12:36 PM
ReAX's Avatar
ReAX
Another option would be Pacer, www.pacerperformance.com/
They make clear and smoked lamps. I recall jobber being in the $50 range, but that was several years ago. Install is pretty simple, as long as you don't mind drilling holes in the roof. I would pick up some strip caulk before the install.
Old Jul 1, 2009 | 03:42 PM
TexasRebel's Avatar
TexasRebel
https://www.ford-trucks.com/forums/8...l-writeup.html
I put these on back in January.
If you have any questions about it, I'd be more than happy to answer.
If you get the kit, you don't have to splice wires into anywhere... there is a handy plug on the driver side.
HearseDriver
Mar 18, 2019 06:00 PM
SuperDutyScaler
Sep 6, 2014 12:21 AM
Fraalan
Jan 10, 2014 10:19 PM
Shadowrider123
Nov 30, 2012 08:03 AM
Jerrod
Mar 29, 2004 10:30 AM
