Sponsored by: Real Truck
Totaled...
Old Jul 1, 2009 | 02:52 PM
  #91
cartmanea's Avatar
cartmanea
Originally Posted by whits
sorry,just read this. you have the right to tell them where you want to have the truck fixed, so use the highest estimate you can get as a bargaining tool. rebuilts usually value between 75-80% of book, that is what banks and courthouses go by. if you pull it try hooking a fabbed plate or tube attached between the frame rails at the bumper mounts so it all pulls back together.also i know ford sells new bumper mounts that just slip over what is left after you cut off the bent ones for f150s, don't know about sd.good luck!
I plan on having the frame pulled at a local shop. I did it the first time with two large trees and a 8k pound Warn winch with 4 pulley blocks This time both rails are bent sideways and up. After they pull it straight I'll weld on new bumper brackets.
Old Aug 12, 2009 | 01:40 PM
  #92
1975StroppeBaja's Avatar
1975StroppeBaja
bump!
Any update on this?
Old Aug 12, 2009 | 02:04 PM
  #93
cartmanea's Avatar
cartmanea
Still no settlement, this is getting ridiculous. Got the frame straightened a few days ago so at least it drives straight now and nothing rubs. Heading home today to do some panel realignments and work on the areas that are easy touch-ups.
Old Aug 12, 2009 | 02:42 PM
  #94
ehchvac's Avatar
ehchvac
When I had that same bumper on my 04 f350 supercab diesel I loved it, but it always made me a little nervous, since it said on the paperwork that came with it that it was for offroad use only.
I always feared hitting someone like you did, that bumper would kill them deader than he**.
That top prerunner bar is just the right height to hit someone in the teeth.
I kind of suprised that you didnt get the person driving the other truck in the head.
All it would take is a slick lawyer regardless of who is a fault.
Dont get me wrong if offroad tech starts making them for the later model trucks I am going to buy another, but I will still be nervous.
Old Aug 12, 2009 | 03:06 PM
  #95
FortyFords's Avatar
FortyFords
They usually are fixable ,nice truck
Rich
Old Aug 12, 2009 | 03:29 PM
  #96
cartmanea's Avatar
cartmanea
It was a stock '95 F150 that I hit and the top pre-runner bar hit the door just below the glass. If it were a car, I would have gone over it and that would have been ugly.
Old Aug 12, 2009 | 05:11 PM
  #97
rockstate45's Avatar
rockstate45
How fast were you going?
Sucks botu the truck but at least you're both alright. I've heard a lot of "bumper tough" stories and have a few of my own.
Battle scars are usually the best, unless it actually does real damage (all three times my truck has been in an impact I've come out with no metal damage, except to the powdercoat)
-rockstate
Old Aug 13, 2009 | 12:24 PM
  #98
cartmanea's Avatar
cartmanea
I had been doing 25, slowed to about 10 at impact. If it were straight on it wouldn't have bent the bumper, but she was going about 30 through the intersection and the main vertical brace caught on the back of her door opening (I had sheet metal hanging off it like a can-opener). The side force bent the vertical braces and bent the frame sideways which put the driver's fender edge into the door. Then I got pissed at it binding and shoved the door open instead of thinking and getting out the passenger side. Anyway, got the frame straightened and all the body panels look like they are aligned well, so the core support seems to be okay.
Old Aug 15, 2009 | 10:02 AM
  #99
Furian's Avatar
Furian
You Keep What You Kill
So it sounds like you are currently driving the truck and doing all the repairs yourself... Is that correct?
Old Aug 15, 2009 | 11:19 AM
  #100
bunklash's Avatar
bunklash
What a bummer. I'm not one to advocate litigation for unjust enrichment, but for just compensation I think it's appropriate. When my daughter's car got totaled by another driver in a hurry, a lawyer friend represented her to the other guy's insurance company. I'm certain we got appropriately compensated without having to sue. The right lawyer knows how to deal with the insurance companies to keep them from ripping you off. Otherwise you're pretty much at their mercy. Just a thought, and good luck to you.
Old Aug 16, 2009 | 05:07 AM
  #101
cartmanea's Avatar
cartmanea
Doing the repairs myself, correct, and working on it slowly between school.
Old Aug 16, 2009 | 10:09 AM
  #102
mrford60's Avatar
mrford60
you know it is fairly easy to put a front section of the frame on, Ford sells just the front section it welds on just in back of the front suspension. it to bad you are all the way across the country from me, i have a good used front frame section, and could help you do it.
Old Aug 16, 2009 | 11:49 AM
  #103
cartmanea's Avatar
cartmanea
Got the frame straightened last week, turned out really well. Did a quick touch up of the fender edge and hammered the door edge down - looking for a good condition white driver's door. Now I need to cut off the front bumper brackets and weld new ones on the frame rails, straighten my bumper, and should be good to go.
Old Aug 16, 2009 | 06:51 PM
  #104
T8R's Avatar
T8R
Proud of you for doing so much of the work yourself. How hard is it to replace the bumper brackets? Mine are a little tweaked, but not noticeable enough to have done anything about yet.
Old Aug 17, 2009 | 01:54 AM
  #105
cartmanea's Avatar
cartmanea
You have to cut the old ones off and weld the new ones in place, being sure to align them properly. Then you have to re-do the corrosion protection on the frame. If yours are just a little tweaked I'd straighten them before replacing.
