Sponsored by: Real Truck
Totaled...
Old Jun 28, 2009 | 12:31 PM
  #76
senix's Avatar
senix
years ago you could buy undercoating spray paint. I used that alot.
Old Jun 28, 2009 | 12:40 PM
  #77
Ace!'s Avatar
Ace!
This wouldn't be a bad place to start
http://www.a-sp.org/database/custom/...Protection.pdf
Old Jun 28, 2009 | 12:41 PM
  #78
cartmanea's Avatar
cartmanea
You can still get that, but I want something on the frame first that is a corrosion preventative, undercoating wouldn't be much better than paint since it doesn't neutralize existing rust.
Old Jun 28, 2009 | 12:42 PM
  #79
cartmanea's Avatar
cartmanea
Holy information overload Batman!
Thanks
Old Jun 29, 2009 | 01:12 PM
  #80
a-rod's Avatar
a-rod
Originally Posted by cartmanea
Adam, since you do collision work you may be the one to ask. After I weld on new flanges on the ends of the frame rails, what is the best product to use for recoating and corrosion protection of the frame? Last time I just shot it with black paint and it rusted in no time. Do you use something like POR-15 in your shop or something else? Also thinking about getting the frame ends LineX'd when all is said and done.
We just use a good 3M undercoating, seems to hold up good. Did you check to see if your frame was buckled around the engine cross-member area? Judgeing by the pics its gotta be bent.
Old Jun 29, 2009 | 01:25 PM
  #81
cartmanea's Avatar
cartmanea
The bulk of the force was sideways and up, my angled pre-runner bumper pulled the rails up because it got pushed up against the grill. It looks to me like it just needs a side pull and then get the up and down correct. I think I'll shoot the frame ends with some real good primer, maybe use a rust converter first, then do either Herculiner or just undercoating.
Old Jun 29, 2009 | 01:53 PM
  #82
Angrywasp's Avatar
Angrywasp
I would recommend a rust converter, primer (self etching), and then the undercoating vice the Herculiner. The Herculiner is real thin so it'll scratch off fairly easy. LineX would be the best bet to protect it permanently.
Old Jun 29, 2009 | 02:25 PM
  #83
cartmanea's Avatar
cartmanea
I was thinking LineX at first, probably will go with that.
Old Jun 29, 2009 | 02:47 PM
  #84
senix's Avatar
senix
that would be cool...line-xing the frame!
Old Jun 29, 2009 | 05:49 PM
  #85
Maxium4x4's Avatar
Maxium4x4
Just remember the Line X is a Pita to get off in the future. I always blasted the frame rust and used epoxy primer before I painted. John Deere has soft black that looks original for the frame.
A-rod should be shaking his head about now.
Old Jun 29, 2009 | 06:07 PM
  #86
T8R's Avatar
T8R
Sorry to hear that
Everyone was fine. My bumper was folded up against the grille and pushed sideways. The driver's side of the '95 F150 I hit looked a lot worse. I was able to drive it home at least, but there is definitely frame damage.
Sorry to hear that, it's a great looking ride. The bumper actually held up pretty well all things considered. My Yukon went through the same thing a few weeks ago. (someone ran a light) It was about 3ft shorter after the collision, and is why I am now the proud owner of my first SD. :-)
Looks like the bumper was money well spent.
Still, sorry to hear about your luck. Good luck getting everything sorted out and put back together. Keep us posted.
Old Jun 29, 2009 | 07:47 PM
  #87
msgtg's Avatar
msgtg
Welcome to the group tater!
We're a pretty good group to hang out with! Lots of good truck info here!
You need to hook up with Stevie Bricks out there....
Joe
Old Jul 1, 2009 | 02:23 AM
  #88
whits's Avatar
whits
sorry,just read this. you have the right to tell them where you want to have the truck fixed, so use the highest estimate you can get as a bargaining tool. rebuilts usually value between 75-80% of book, that is what banks and courthouses go by. if you pull it try hooking a fabbed plate or tube attached between the frame rails at the bumper mounts so it all pulls back together.also i know ford sells new bumper mounts that just slip over what is left after you cut off the bent ones for f150s, don't know about sd.good luck!
Old Jul 1, 2009 | 05:52 AM
  #89
HeavyAssault's Avatar
HeavyAssault
Damn if you were not so far there's a rolling chassis on Craig's List for sale out of PA.
Old Jul 1, 2009 | 07:11 AM
  #90
msgtg's Avatar
msgtg
Heavy...I like that Ford Drag Team avitar. Now are you talking about real drag racin' or dragin' the trailer...LOL!!!
Joe
