Do You Need To Change Diff. Oil?
Old Mar 21, 2002 | 05:23 PM
motobub's Avatar
motobub
Do You Need To Change Diff. Oil? How often, and do I need to put anything special in my diff, with a L/S?
Old Mar 21, 2002 | 06:04 PM
Wilber15's Avatar
Wilber15
You should change your differential oil...yes. I don't know how often. Look in your owners manual and it will tell u the weight to use. I think mine uses 80 weight Gear Oil. just take the cover to the pumpkin off and drain the oil. then scrape the old RTV( if any was used) and reapply the cover. fill through the hole in the back near the driveshaft insert.
Old Mar 21, 2002 | 10:57 PM
Ryan50hrl's Avatar
Ryan50hrl
if you use your truck hard, i'd recomend twenty to thirty thousand mile intervals. Mine always seems to find some way to get water in it.
Ryan
Old Mar 22, 2002 | 05:14 PM
72_ford's Avatar
72_ford
Old Mar 22, 2002 | 07:38 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=2509&.jpg
ryanf250
Oct 31, 2012 03:37 PM
kellens
Mar 21, 2008 07:43 AM
97 HD
Jul 19, 2007 05:24 AM
crack
Jul 3, 2007 05:22 PM
cravenc
1997 - 2003 F150
Mar 15, 2006 07:55 AM
