Axle code differences
Old Mar 22, 2002 | 09:08 AM
cw50must's Avatar
cw50must
The cod on the door of my '84 says 18 for the axle. I was told this is 3.08 with an open diff. I was under the back so I tried to read the tag on the rear, it says 3L08 (actually it looked like 3L03, but that has to be an 8) Someone else told me that is 3.08 limited slip. Which one is correct? It sure acts like an open diff, but it could just be the clutches are worn out.
Old Mar 22, 2002 | 05:14 PM
72_ford's Avatar
72_ford
Ok I believe that you have a 3.08 gear with a limited slip. There is no 3.03 gear available. The L in 3L08 means that you have a limited slip. If I remember right.
Old Mar 22, 2002 | 07:46 PM
pcman's Avatar
pcman
My truck also has a 18 axle tag in the door. I looked in the owners manual and it said it was a 3.08 ratio open differential not limited slip. My truck is a 1990 but the numbers will be the same because your rearend is a 8.8" too.
Old Mar 23, 2002 | 03:08 PM
twj721's Avatar
twj721
