1995 windshield trim removal?
Old Jun 8, 2009 | 11:49 AM
SaikotikGunman's Avatar
SaikotikGunman
I've got pretty significant leakage when it rains or I hose off my truck, all along the top of the windshield. What's the best way to remove the chrome trim without damaging it, so I can reseal my windshield?
Old Jun 8, 2009 | 12:14 PM
goodB0Y's Avatar
goodB0Y
the best way is to use the proper tool for removing it... or you could go to a glass shop and have them remove it for you.
I managed to get some off while I was at the wreckers with a screwdriver... but I bent 3 sets before I got it off...oops!...lol
Old Jun 8, 2009 | 12:16 PM
SaikotikGunman
I'd practice on my donor truck, but there's a reason it's a parts truck, and that reason is that I... uh... modified the cab a bit... with a hay field.
What, exactly, is the proper tool?
Old Jun 8, 2009 | 12:30 PM
goodB0Y's Avatar
goodB0Y
I don't know really...never seen one. I just know that there is a windshield trim removal tool that glass and body shops use...
Old Jun 8, 2009 | 12:34 PM
SaikotikGunman
This is starting to sound like some mystical, magical relic of legend, now.
How about a long thin screwdriver wrapped in electrical tape to prevent scratching?
If I knew what this tool looked like, I could make myself something like it, perhaps.
Old Jun 8, 2009 | 12:39 PM
goodB0Y's Avatar
goodB0Y
google is your friend... a quick search found this:
4 Piece Auto Windshield Door Clip Trim Removal Tool Set:eBay Motors (item 270396648032 end time Jun-23-09 18:35:07 PDT)
Old Jun 8, 2009 | 12:45 PM
SaikotikGunman
Thanks... that gives me some ideas. Maybe I can use some of my old damaged trim as a guide and make myself a trim remover.
Old Jun 8, 2009 | 01:16 PM
Prozon's Avatar
Prozon
Just don't rush into it too fast. I severely damaged my trim. Popped off fine the first time, but the second time I busted it up bad.
(I had some leaking issues on my cab.)
And now I have no trim and a **** load of windshield sealant. :P I figure i'll take the trim from the parts truck and have the shop replace my windshield when I have some spare cash.
Old Jun 8, 2009 | 01:22 PM
SaikotikGunman
I'll see if enough is left of the windshield frame on my donor truck to practice on, but I highly doubt it.
Old Jun 8, 2009 | 01:43 PM
Diesel_Brad's Avatar
Diesel_Brad
here is the correct tool KD Tools. It must be kept flush to the window,if not you will crack the glass.
Old Jun 8, 2009 | 01:50 PM
White 97 xlt's Avatar
White 97 xlt
Yes, this is what you need... It is the ONLY way to safely remove the trim with out bending the trim, scratching the glass, or bending the clips so bad they can never be reused....
Old Jun 8, 2009 | 01:54 PM
SaikotikGunman
Just what I need, more cracks in my windshield...
Might just have the auto glass place in town pop it off for me.
Old Jun 8, 2009 | 02:12 PM
Diesel_Brad
i would practice on your parts truck. Once you use the tool you will know what is right and what will brake the window
Old Jun 8, 2009 | 02:28 PM
SaikotikGunman
The windshield is shattered out of my parts truck, hence why I've not had a chance to try it on anything.
Shane in WI
24
May 20, 2016 08:40 PM
AbandonedBronco
1978 - 1996 Big Bronco
Oct 25, 2015 07:40 PM
baverwolf
Oct 31, 2014 03:27 PM
Kalve
18
Mar 28, 2011 11:55 PM
HB_BD
Oct 28, 2010 10:19 PM
