removing windshield trim
Old Oct 30, 2014 | 11:20 PM
baverwolf's Avatar
baverwolf
I've got an 86 F150 that I'm in the process of painting and am curious as to how to remove the chrome trim around the windshield?
Thanks!
Old Oct 31, 2014 | 01:25 AM
Trackerrrr's Avatar
Trackerrrr
There's a special trim tool that's shaped like an arrow that inserts under the trim. You then use it to lift the retaining clip that will release the trim. Do a Google search for windshield trim tool and you'll see what I mean.
Old Oct 31, 2014 | 01:26 AM
Trackerrrr's Avatar
Trackerrrr
You need to be very careful when releasing the clips. You can chip or crack the edge of the windshield if you get aggressive with the tool.
Old Oct 31, 2014 | 04:22 AM
Trackerrrr's Avatar
Trackerrrr
This link shows how it's done. It's on an older Chevy car but it's pretty much exactly the same. If you jump to 4:52 you can see how the clips are released to get the trim off, with the trim already off.
Old Oct 31, 2014 | 06:54 AM
Franklin2's Avatar
Franklin2
I never have very good luck with the tool. I use a putty knife, get under the trim, and lightly pry. You can feel where the trim is moving less in certain areas, and that's where the clips are. I gently pry at the clips, and take the side pieces of trim off first going up each pillar. I then use a combination of sliding/prying on the two top pieces and the two bottom pieces.
When you pry some of the clips underneath may go flying, so try to round them up and not lose them. You can bend them back in shape and re-use them.
Old Oct 31, 2014 | 08:11 AM
baverwolf's Avatar
baverwolf
Thanks everyone for the replies!
Old Oct 31, 2014 | 03:27 PM
Trackerrrr's Avatar
Trackerrrr
Ditto on Franklin's advice. The clips can also be rusty and break so plan on that also.
mike83f250
Oct 11, 2019 09:55 AM
Hitokori
Jan 27, 2010 07:09 AM
netscaner
Sep 9, 2008 05:48 AM
Ranger GT2
Paint & Bodywork
Feb 18, 2008 07:04 PM
My Ford Truck
Mar 22, 2003 08:45 PM
