Tailight diffrences?
Old Jun 7, 2009 | 05:45 PM
Vinford's Avatar
Vinford
So I was looking at a 73 Ford yesterday and it had 4 screws holding the tailight in.
4 exposed screws.
1 on the top , 1 on the bottom and 2 in the middle side by side.
Ive owned a pile of old Fords and have never seen that before?
The guy with the truck said they were all that way.
Anyone ever seen it before?
Old Jun 7, 2009 | 05:57 PM
shanes66charger's Avatar
shanes66charger
not sure, but i think there was some differences in the older tailights. I have never seen four screws though?
maybe someone else knows more.
Speaking of tailights, DID 73-79 all use gaskets from the factory?
thanks guys
Old Jun 7, 2009 | 06:00 PM
scrapyardking's Avatar
scrapyardking
I think the 73's hade the same style tailights as the 67-72's.
Old Jun 7, 2009 | 07:22 PM
Jermafenser's Avatar
Jermafenser
1973/74 F-series before serial #T00001 used separate metal bodies and lenses.
1974/79 after T00001 uses the more common integral molded tail lights.
No gaskets on taillights. That was for the 1975/91 E-series only.
Old Jun 7, 2009 | 10:28 PM
shanes66charger
ah......on the vans. that makes sense.
I was wondering what purpose the gasket would have on the truck. lol
cheers, gonna suck down a beer and go horizontal for about 6 hours.
Old Jun 8, 2009 | 09:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Styleside pickups:
1974 F100/350's after serial number T80,001; 1975/79 F100/350's use the same taillamps as 1975/91 Econolines.
The Econoline gaskets peel right off.
The taillamps used on all 1973's, 1974's before serial number T80,001 are not the same as 1967/72's.
These right/left taillamp lenses were available separately from the metal bodies and use (4) #8 -18 x 1 1/8" screws per side to attach the lens to the body.
Old Jun 8, 2009 | 10:09 AM
Vinford's Avatar
Vinford
Its the 4 screws that get me.
Old Jun 8, 2009 | 12:52 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The two center screws hold the lens to the housing, and the two outer screws hold the lens and housing to the bed of the truck.
BTW on the 1973-1974 trucks before T80001, the taillamps do have a gasket between the lens and the metal lamp housing, to keep water out of the metal housing.
Old Jun 8, 2009 | 01:07 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's quite the pain in the butt to change bulbs. Also when the gasket is getting nasty and ragged and you start installing screws and crack the lens.
I just convert to the modern version and be done with it. 2 screws and it's all sealed nicely.
Josh
joel79ford
15
Nov 13, 2012 06:10 PM
philtruck
New Member Introductions
Feb 16, 2008 06:07 PM
ceetwarrior
Oct 28, 2003 12:07 PM
DMoffroad
Oct 21, 2003 05:46 PM
76RangerXLT
17
Apr 10, 2002 11:32 AM
