Highboy front shock mount question
Old May 29, 2009 | 09:13 PM
peganit2's Avatar
peganit2
The lower shock mounts on my 77 F250 4WD are completely different side to side. Driver side is a big forging and the passenger side is a little stamped piece of sheet stock. Both are welded on. Is this the way they're supposed to be?
Old May 29, 2009 | 09:30 PM
montana_highboy's Avatar
montana_highboy
They are different mounts between passenger and driver side, i believe the drivers side mount is angled outward to clear the steering knuckle/drag link on right hand turns.
Old May 29, 2009 | 09:54 PM
peganit2's Avatar
peganit2
That's crude.
The right shock is angled backward and the left is angled forward.
Old May 29, 2009 | 10:35 PM
montana_highboy
What axle do you have under there?
Old May 29, 2009 | 10:43 PM
montana_highboy
dana 44 or dana 60?
Old May 30, 2009 | 01:44 AM
peganit2's Avatar
peganit2
It's a 44....
Old May 30, 2009 | 02:12 AM
bucks77ford's Avatar
bucks77ford
Here is a decent pic of how mine are with a 44.
Old May 30, 2009 | 02:23 AM
peganit2's Avatar
peganit2
Is that an illusion or are top of the shocks staggered?
Nice work by the way.
Old May 30, 2009 | 10:37 AM
montana_highboy
I went out this morning and took a look, the drivers side lower shock mount sets back from the axle tube about 2" further than the passenger side mount, when you take a look at it then it becomes obvious it's set back that way to clear the steering knuckle on right hand turns.
Old May 30, 2009 | 11:39 AM
75F350's Avatar
75F350
This change in angle of the shock combined with the shock mounting location changes tthe overall dampening from side to side, and this is one reason why the HB trucks ride a little funny.
The dampen a little different form side to side, and get worse after they have been lifted.
Old Apr 29, 2010 | 10:47 AM
70 Bronco TX's Avatar
70 Bronco TX
I figured I wouldn't start a new thread....here's my shock mount "breakage" below. Three pics, first two are the driver's side and third is the passenger's side (still intact).
Don't know how long it's been this way, probably since I got it in August and never noticed. Front driver's side lower shock mount. Somehow it's still seated--wow. I haven't done much more inspection than this but a pal and I are going to fix it soon.
Question: Should I a) fab something to patch it--doesn't have to look pretty, or b) cut off the old one, put a new one on, or c) cut it off and fabricate something? I guess it depends on skill, access to parts, etc. but any thoughts are welcome
Outlaw56
Mar 2, 2015 07:37 PM
JLR1953
Mar 13, 2014 05:56 PM
kabur66
6.7L Power Stroke Diesel
Sep 19, 2013 06:29 AM
pym
Sep 11, 2011 11:57 PM
loghomeman
Jan 9, 2005 08:28 PM
