Electical Problem? Wiring Harness?
Old Feb 8, 2009 | 08:42 AM
schalkie's Avatar
schalkie
4wd High
I have a strong running '78 F-250. Occasionally though I have a problem that I can't find the root cause for. The truck normally starts right up on one click and runs great. There are times though that I am crusing along and I can feel it lose spark just for a second or two. Other times it will stall while I am on the throttle and rolling- just like I had turned off the key. I can throw it in neutral and it will usually start right back up like nothing happened and I keep driving. Lastly, sometimes it won't start, it will turn over like it has no spark at all so I stop, come out 10 minutes later and it will start on first click. I have replaced my battery (since it was time anyway), positive and negative battery cables, coil and coil wires, cleaned grounds to bare metal, and cleaned up all connections to the solenoid and alternator. Any other wire connection under the hood I could find I took apart, cleaned up, and put back together with dielectric grease. Is it my wiring harness? How do I check it, and then where is a good place to get one? Thanks for your time people...
Old Feb 8, 2009 | 08:57 AM
Red Ford Truck's Avatar
Red Ford Truck
Sounds like it's your ignition box
On the fender, they sometimes stop working completely but many many times are intermittent in their operation which can be dangerous so being as they are so cheap to replace go ahead and do it just make very sure you replace it with the correct one, also make sure the one you have now is the right one to start with.
Or it may just be corrosion in the plug or plugs that attach to the box.
Also there is a special high altitude one I believe it has something to do with advancing the timing if I remember correctly.
Rick.
Old Feb 8, 2009 | 09:14 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's either the ignition module or the stator pick-up in the distributor. Both exhibit the same symptons when they are on the way out.
Josh
Old Feb 8, 2009 | 09:52 AM
fmc400's Avatar
fmc400
MSEE
100% agreed on the module or pick-up. There are tests you can run on these, but unfortunately the symptoms are usually brought on by heat, so if you're parked in your driveway after the motor has cooled off or you take the module into the parts store to be bench tested, it won't show any problems.
Old Feb 8, 2009 | 10:33 AM
Bullitt390's Avatar
Bullitt390
I'll add that years ago my truck started doing that. It didn't matter what the temperature was, I could have just started the truck for the first time that day and after 45 seconds just shut off. But it would instantly start right back up once you hit the key.
Or it would die going down the road, shift into neutral like you said, hit the key and start right back up.
What I ended up doing was I got some spare inner fenders from the junkyard which still had a module mounted on it. Put that one on my truck and the syptoms seemingly went away, only to return maybe 2 years later. Swapped back to my original module, but replaced the pick-up in the distributor and done deal.
It's pain in the butt a little, but oh well.
I do notice the parts store have quite the range of prices for either the module or pick-up. So I suppose buyer beware.
Old Feb 8, 2009 | 11:00 AM
Jodell's Avatar
Jodell
Should be able to pick up the ignition module in the JY for a cheap test. Just make sure to look at yours where the wires go into the box and note what color the plastic is. I think there is a blue kind and a yellow kind.
Old Feb 8, 2009 | 11:21 AM
Bullitt390's Avatar
Bullitt390
There are several "colors" with Blue being the most sought after. Along with the yellow there are White, Red, Purple, Green and Black.
Not sure of the exact differences, but some are California and others are hi-altitude.
Josh
Old Feb 8, 2009 | 11:53 AM
VocaTexas's Avatar
VocaTexas
My '76 Crew Cab (460) used to do the same thing. As a matter of fact, this is the reason it was for sale when I bought it. I had owned it nearly a year when I finally discovered the cause: where the wiring harness comes up over the back of the bellhousing and runs along the intake manifold check VERY CLOSELY that there isn't a very small break in the insulation. Mine had a worn spot so small I could hardly see it, but when it got against the manifold it would kill the engine.
As for modules, you can get them at any NAPA store, or at least you could less than a year ago. I had to buy a new one for my '79 when mice chewed the wires off it.
Old Feb 8, 2009 | 09:29 PM
schalkie's Avatar
schalkie
4wd High
I will try that!
Thanks for the info everyone, I will get an ignition module first thing tomorrow and go from there!
Old Feb 10, 2009 | 09:29 PM
schalkie's Avatar
schalkie
4wd High
Hit the nail on the head.
You guys were right. I am back on the road with a new module. Haven't had the same problem and I got it good and hot on a 52 degree day and it never flinched. I have my confidence in her back, Thanks!
Old Feb 10, 2009 | 09:38 PM
Bullitt390's Avatar
Bullitt390
Sweetness!
Old Apr 28, 2010 | 06:12 PM
barebackbob's Avatar
barebackbob
Exclamation where can i pick up
where in the world can i pick up a whole new wiring harness my 1986 ford bronco with a 302? and will it come with everythin that runs from my coil to my duraspark and then to my distributer?
Old Apr 28, 2010 | 07:22 PM
D24x4's Avatar
D24x4
Wiring Harness
Take a look at Ron Francis they have several for Fords. Prices are good too compared to Painless. Try Google for your truck there should be quite a few.
Mark
Old Apr 29, 2010 | 11:29 AM
barebackbob
right on ill try that thank you
RIKIL
17
Jan 6, 2014 08:42 PM
luthoro
22
Aug 1, 2011 02:10 PM
mxhowes1
Mar 3, 2008 10:05 PM
BobcatGuy
Feb 19, 2007 10:41 AM
DrFord
Electrical Systems/Wiring
Dec 25, 2005 01:07 PM
