FatMat install results
Old May 28, 2009 | 09:36 AM
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by CampSpringsJohn
This sounds like something that would make my wife appreciate my truck a little more.
She will, that and the Bilsteins are about the only two mods my wife appreciates.
Old May 28, 2009 | 10:10 AM
bigtexan99's Avatar
bigtexan99
I did not take any pics! Sorry. If you search the board for sound deadner or dynamat, you will find a thread with a bunch of excellent pictures. It may be in the SuperDuty board.
I probably used about 140 sq feet, but I also did the underside of the engine hood. Actually bought 200 sq feet and a friend of my did his nissan frontier truck at the same time.
100 feet should get the job done.
Removing the headliner was extremly easy. It's just held up by 4 push plugs and the rubber door trim. Be sure and wash your hands before touching it! Also, do not remove the headliner from the cabin, it won't fit out the doors on a supercrew. Has to go out or in the back or front window. Just rest on the seat headrests and work around it.
Old May 28, 2009 | 10:14 AM
bigtexan99's Avatar
bigtexan99
photos
Here is the link to the thread with photos
https://www.ford-trucks.com/forums/6...s-present.html
Mine did not look anywhere near that professional when it was done! But it works.
Old May 28, 2009 | 11:06 AM
PaysonPSD's Avatar
PaysonPSD
Thanks for the link with picks bigtexan99. We'll fore give you for not having your own.
Old Jun 3, 2009 | 06:33 PM
chayes01's Avatar
chayes01
I've read on some other websites about the smell associated with Fatmat since it's an asphalt base and that it tends to fall off of vertical surfaces. Have you had any of these problems? I've been looking at both Fatmat & Dynamat.
Old Jun 3, 2009 | 06:56 PM
zx250's Avatar
zx250
Nope, not with my B-Quite (Dynamat) and it has sit at boat ramps in 100 degree heat all day and still no smell and I promise you that stuff is so sticky it ain't falling off nothing.
Old Jun 6, 2009 | 11:55 PM
bigtexan99's Avatar
bigtexan99
Agree with you on the stickyness, can't imagine fatmat falling off, its sticky.
I have noticed a smell. In fairness, I put ALOT of that stuff in my cab. Also, I drive with the air on MAX recirculating and windows up.
The odor is weaker than the first couple of days, but it is still faintly there. Seems to be dissipating over time.
Old Jun 7, 2009 | 02:01 AM
zx250's Avatar
zx250
I will admit that mine has been in for a while now and it may have had a slight smell to start, but nothing now. I don't remember it, but it could have been.
Old Jun 7, 2009 | 02:18 AM
JockD's Avatar
JockD
Other Sources:
I have not done this yet, but I did research sound deadeners and have three other suppliers that have good reputations for performance:
RAAMaudio
RAAMaudio - Quality and Value in Automotive Sound Deadening
Second Skin
Acoustic Vibration Dampening Mat
Cascade Audio Engineering
Cascade Audio Engineering – Sound Damping and Sound Blocking – Anything Else is a Compromise
In my research the asphalt-based materials had the most complaints. Smell and heat tolerance. Sound deadening ability is closely linked to weight, so a light-weight material will be expected to be less effective at dampening. To an extent, this can be overcome with engineering and material selection.
Reflective surfaces are good at keeping heat (or cold) on the side they are facing. Some vehicle companies have installed reflective insulating sheet near the exhaust system to keep heat out of the passenger compartment. I used reflectorized insulating "bubble wrap" in the floor and ceiling of an old E350 van and it made a world of difference in keeping it warm in the winter and cooler in the summer. When I get around to doing my F250 I want to use reflectorized deadener on both sides of my firewall and under the passenger side floorboard. Reflective surfaces work best when facing an open area or have a gap so they don't touch something on the shiny side.
Other commentators mentioned that the roof is important for powerful audio systems and general road noise. Less important for engine/exhaust noise. Doors are suprisingly important for engine noise, and obviously for audio quality. The best suggestion was to use deadener on the door skin and also use deadener to replace the water barrier between the inner door skin and the door upholstery panel.
Old Sep 10, 2009 | 10:50 PM
bigtexan99's Avatar
bigtexan99
4 month update
An update after 4 months. The slight chemical odor that the fatmat was putting out has long since disappeared.
Everything still stuck on well.
The interesting part is that my perception of the noise quietness has gone away. I'm sure its still just as quiet, but I can't remember how noisy it sounded before.
wallew
Oct 26, 2017 06:35 PM
Norma stitz
Oct 6, 2016 05:01 PM
Outlaw56
Apr 6, 2015 11:37 AM
calshamus
15
Oct 8, 2011 10:16 PM
fumminsplease
Mar 11, 2011 12:28 AM
