Engine dies
Old Sep 10, 2009 | 07:25 PM
crazymut's Avatar
crazymut
Engine dies
Ok two days in a row now my truck has died. The first time was after running for about a min, a/c turned on, put in gear and just starting to pull away. Restarted all was good. Second time, turned truck on, let idle stabilize, flipped on a/c, truck dies. Restarted all was good. I have an idea it is the cps but this time it is totally different semptoms than any other time. Any ideas?
Old Sep 10, 2009 | 08:53 PM
F350-6's Avatar
F350-6
Not really enough info for anything other than wild guesses. I'm guessing after the restart you don't have a CEL? Any idea if there are any codes stored? Random things are hard to chase down, but if the problem starts to become predictable, it's easier to track down.
For instance, the 2 things you mentioned are shifting into gear and turning on the AC. If the stall starts showing up on a frequent basis, you could try not turning on the AC, or starting in neutral and then shifting into reverse or drive (whatever is opposite of what you normally do) to help pinpoint the action that is causing the stall.
Go ahead and give us a better description of the stall too. Is it more like someone just turned the key off, or does the engine sputter a bit first?
Old Sep 10, 2009 | 10:03 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Just a shot, have you tried another CPS?
Old Sep 11, 2009 | 12:02 AM
crazymut's Avatar
crazymut
It did it after sitting the day while at work. High 90's close to 100. Does not do it in the morning or after running for a period of time. There is a ses light but I already know that the glow plug controller has a problem, p0683. The first time the a/c was already on then I shifted into gear move about 10 feet a died. The second time it did it as sone as I turned on the a/c. Just like someone turned the key off. No spuddering.
Old Sep 11, 2009 | 12:04 AM
crazymut's Avatar
crazymut
Not yet I am going on a trip, in another truck, and will do the cps recall when I get back. I will probably buy another cps for a spare while at it. They are only $30 now from Ford.
Old Sep 11, 2009 | 12:28 AM
WA.Ranger's Avatar
WA.Ranger
Just a thought other than cps, maybe your DP is coming loose? Shot in the dark......
Old Sep 11, 2009 | 12:33 AM
crazymut's Avatar
crazymut
Will have to check that. Did not think of that. But if it came loose would the truck die or revert back to stock?
bertha66
Aerostar
Aug 19, 2012 11:12 AM
Rick6
2004 - 2008 F150
Apr 20, 2006 05:39 PM
oshoguno
Jul 1, 2003 04:53 AM
shelbyowner
1983 - 2012 Ranger & B-Series
Jul 11, 2002 07:11 PM
