Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Air compressor question
Old May 26, 2009 | 09:55 PM
Lead Head's Avatar
Lead Head
I would set them upright to make draining water easier. I don't think a U in the pipe will allow all the possible water in the tanks to drain out.
Old May 26, 2009 | 10:11 PM
Bill W's Avatar
Bill W
should i use a glass bowl water seperater somewere in the line?
would that be good enough?
my thinking was If the compressor sat for a bit the water would drain into the U, then you can open the valve and blow the water out.
Old May 26, 2009 | 10:15 PM
Lead Head's Avatar
Lead Head
on the air output yes, but you really can't do to much about water that will collect in the tanks it self from condensation.
Old May 26, 2009 | 10:17 PM
Bill W's Avatar
Bill W
your quick! i edited the post after you posted....
water should drain into the U and then can be let out?
Old May 27, 2009 | 03:43 PM
Lead Head's Avatar
Lead Head
I don't quite follow? You will need a drain on the bottom of the tanks to drain water. Water that collects in the tank won't follow the air stream I think to well.
Old May 27, 2009 | 09:23 PM
Bill W's Avatar
Bill W
Thanks Ian, we will see how it comes together, I'm thinking that i will use only 1 tank.
The other would make a Awesome smoker!
Old May 28, 2009 | 11:50 AM
Ford_Six's Avatar
Ford_Six
You really do need to either mount the tank vertically or with the side nipple on the bottom so the moisture can drain. Otherwise, they'll gradually fill with water and you'll lose capacity, not to mention the increased risk of rust and failure.
Carolina 52
25
Mar 24, 2013 07:37 PM
taneum
13
Dec 23, 2012 09:42 PM
DMch
Garage & Workshop
Nov 23, 2008 07:38 AM
Joeymt3
Garage & Workshop
Sep 29, 2008 11:08 AM
Wes64052
Garage & Workshop
Feb 26, 2004 05:06 PM
