OT but Here is a Flathead powered Air Compressor
I found a CL ad for an old air compressor powered by a 40's model flathead and it is set up to run on 4 cylinders.
Just cool to see the vintage stuff like this.
1940's Flathead Ford Air Compressor
I was wondering about the V8 flatties, but your half a 4 cyl is going to have one powerstroke per crank revolution. How many rpms for it to run smooth, or as smooth as possible anyway.
This was certainly a unique thing to find for me, anyway. I have only seen diesel powered retired Army generators in this area. I wasn't aware such a thing existed.
It is not running and possibly all that black looking stuff in the fuel pump sedimate bowl is why. I was trying to figure how the fuel pump even worked being atop of the engine. The clamps around the carburetor are puzzling also.
It is set up with a governor but not a tach. I would guess that it runs under load in the 3500 rpm range. I had rebuilt the engine back in the early 80's when the parts were reasonable and I was into Model A's ( I also rebuilt a counter balanced "C" engine in the same time frame that I ran in my 31 Vicky). IIRC I even got a set of NOS rods for under $50. I walked Hershey this year and saw Model A rebuilt blocks for north of $4K!
I remember seeing one a few decades ago that was a Buick V8
I wonder if they used a 6-cyl single barrel carb (Holley 1904)? What do you mean about the fuel pump, that it isn't necessary? The fuel should gravity flow being above the engine. That appears to be the stock flat V8 fuel pump.
check out this schramm intake picture
FORD FLATHEAD GURU's: Unusual flathead stuff - THE H.A.M.B.
while we are discussing interesting setups, Can someone please explain to me what is going on here in this picture?? it looks like something I would have expected to see on my grandpas junkyard in South Dakota as a kid First cadillac powered ford truck I've seen! lol
hmmmm
The very definition of cooty-bob! I'd bet it's how you adapt a Caddy engine to a Ford truck without a machine shop to make an adapter. Take out all the pistons and just use the crankshaft as an adapter. What do the cables going over the roof connect to?? I'd hate to hit the brakes hard...
