Air Compressor Question..........
Old Dec 20, 2012 | 09:37 AM
taneum's Avatar
taneum
I have a 5hp 15gal craftsmen compressor. Minus body work, will this be sufficient in my truck restoration? The only thing I can think of roght now that would use a considerable amount of air would be sandblasting and from what I have hear thus far, my compressor may not be big enough.
Old Dec 20, 2012 | 09:47 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Compressors are rated by cfm output. Check usage of any tool you wish to run off of it. That will tell you what you can do with it.
Old Dec 20, 2012 | 12:13 PM
HIO Silver's Avatar
HIO Silver
15g is too small for a sand blaster. The motor will run all the time and the capacity unable to keep up with the outflow. Ya'd need to step up to at least a 220v 60g version.
A better option may be to deliver it a commercial facility to have it sand or bead blasted.
Old Dec 20, 2012 | 02:00 PM
taneum's Avatar
taneum
Understood......thanks.
Old Dec 20, 2012 | 08:19 PM
jgavac's Avatar
jgavac
Sandblasters require huge amounts of air. Especially the large ones. If you have a small, stand alone blaster, you can use one similar to what HIO Silver suggested. Just make sure you get a twin stage (which is NOT the same as a twin cylinder) compressor. They are designed for continual use, whereas single stage compressors are better for small tools. All depends on the blaster
Jameson
Old Dec 20, 2012 | 10:07 PM
hasteranger's Avatar
hasteranger
you can't go gallon size either, I have a 10 gallon air compressor that does 13 cm at 100 psi...
lol
its one I made, but still.
honestly what you have will do just fine for 90% of use, if yorue using something air intensive like a line sander then you may have to pause to let the tank fill back up... if you get into something and your compressor isn't up to snuff or it craps out from the heavy duty cycle, wait till then to upgrade. no sense spending money just to spend it. as fun as that is.
Old Dec 21, 2012 | 08:26 AM
DeepRoots's Avatar
DeepRoots
IR has a compressor for sale at Tractor supply, 15cfm, 60 gal tank in the $700-$800 range at this time.
Old Dec 21, 2012 | 01:32 PM
lostonmonday's Avatar
lostonmonday
Right now Sears usually has pretty good sales on larger compressors. I spent a month shopping for a 60 gal or bigger last year, and Sears had the best bang for the buck.
Old Dec 21, 2012 | 06:27 PM
dlburch's Avatar
dlburch
when I was doing construction many years ago, the compressor we used was 302 v8 running on 4 cylinders...the other 4 pumped air. If I run across a free 302 I'm going to sit down and figure out how to convert it.
Old Dec 21, 2012 | 06:32 PM
jgavac's Avatar
jgavac
I picked one of those up this summer to power my sandblaster. A Grimmer-Schmidt 302 monoblock. Pumps 125 cfm, which is perfect for my blast cabinet.
Jameson
Old Dec 23, 2012 | 12:14 AM
taneum's Avatar
taneum
On my truck restoration, I am figuring on hiring out most of the body work (i think), if so, what else would I need a new, larger compressor for? Just trying to justify the compressor cost vs. sand/bead blasting the frame. What does frame work like that usually cost if I take it in?
Old Dec 23, 2012 | 12:21 AM
jgavac's Avatar
jgavac
If you just want to sandblast the frame, I would suggest you find someone local to do it for you. It would be much cheaper than buying a compressor and blaster plus media, for just that one job
Jamesom
Old Dec 23, 2012 | 05:57 PM
Blue and White's Avatar
Blue and White
Sometimes compressor hp ratings are "peak" hp not true running HP. They can be misleading.
As posted, CFM ratings are better. For general bodywork (DA, painting, light blasting) 15 CFM @ 90 psi is enough. A compressor this size will draw 20-25 amps at 230 volts. No 110 v unit will do it.
Old Dec 23, 2012 | 09:42 PM
lafermedavid's Avatar
lafermedavid
grimmer-schmidt
nice score on that Jameson,I like to find one with a blown motor I have a nice 302 waiting in the wing,perfect place for that dave
cbzdel
May 23, 2012 08:21 AM
82airborne82
Paint & Bodywork
Nov 9, 2010 07:15 PM
v8xploder
Paint & Bodywork
May 22, 2007 12:35 AM
Oaktree
Paint & Bodywork
Apr 15, 2007 12:55 AM
BIG-COUNTRY
Garage & Workshop
Dec 24, 2005 01:05 PM
