Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Jucuzzi Air Compressor
Old Nov 12, 2008 | 07:30 PM
DMch's Avatar
DMch
I picked up a old jacuzzi air compressor and tank free and found out the motor is 3phase 347 volts. I swapped it for a 120volt motor and the compressor runs sweet. My question is I can't find a users manual on it. It has a turn **** on the top of the compressor that looks like a air adjustment valve of some sort.
When you push it down to turn the air stops coming out but I have no idea what it does when I turn it counter or clock wise.
the model number is 5B301-M40
If anybody has any idea how what his is for please let me Know.
Old Nov 17, 2008 | 06:23 AM
projectSHO89's Avatar
projectSHO89
If the **** is on the air output, it is likely your regulator valve that controls the actual pressure available at the hose port.
Steve
Old Nov 17, 2008 | 06:37 AM
DMch's Avatar
DMch
Thanks for the tip, but the adjustment **** is in the center of the the compressor on the top
Old Nov 17, 2008 | 07:32 PM
Ford_Six's Avatar
Ford_Six
Got any pics? I wasn't able to find anything online about it.
Old Nov 18, 2008 | 12:21 AM
fixnair's Avatar
fixnair
My guess would be a manual unloader. When you push it down or screw it in a pushrod holds the suction valve open and no air is produced. The compressor keeps turning but does not produce any air. Known as a suction unloading valve.
Old Nov 23, 2008 | 07:38 AM
DMch's Avatar
DMch
That sounds like it. When you push it in and turn it it only releases and pops back out, it doesn't screw in or out. No air is produced when it is pushed down. It could be used for start up.
Thanks
Lex77
May 4, 2009 06:28 PM
Lex77
May 1, 2009 10:11 AM
rschleicher
Sep 12, 2008 09:18 PM
AKFord
Garage & Workshop
16
Oct 6, 2004 01:01 AM
