Injector cups?
Old Jun 30, 2009 | 11:11 AM
strokersace's Avatar
strokersace
Originally Posted by goatz
well got that all done but now I can't get her to start, got new glow plugs, new valve cover gaskets changed the electrical connectors that plug into the, but no start all I get get if i leave it cranking over for a bit it tries to fire a bit but nothing. I can see white smoke coming out of the tail pipe so its getting fuel.
Your oil rails probably aren't filled enough. Have you checked the oil level in the resevior? Should be approx. an inch from the top. If it's low then the injectors won't fire and you'll have alot of crank but no start. With smoke too.
Old Jun 30, 2009 | 12:26 PM
goatz's Avatar
goatz
oil level is good
Higgy
Jun 23, 2023 08:56 PM
PaysonPSD
37
Mar 6, 2020 05:29 PM
Jmatthews
Mar 20, 2011 05:33 PM
chrisjrosenbohm
Mar 15, 2010 09:10 PM
KevinC.
15
May 11, 2009 11:12 AM
