Another glowplug thread HAHA
Old May 5, 2009 | 04:31 PM
jmmartin's Avatar
jmmartin
What size wire runs to the plugs and where do they start/split? the insulation has rotted off 7 of them, and i am getting a lot of clicking when i try to start, after the motor is warm they cycle great, but not cold, i am wanting to change the plug feed wires and put new connectors on. i had to change one connector out last week, and it was a blue crimp-on, sorry brain is farting right now,, cant recall the size it is...
Old May 5, 2009 | 04:47 PM
rupejosh's Avatar
rupejosh
you could probably run 14 gauge i believe its a bigger wire than stock but would probably work better.ill see if i can scrouge up a diagram for ya
Old May 5, 2009 | 04:52 PM
rupejosh's Avatar
rupejosh
Old May 5, 2009 | 06:45 PM
jmmartin's Avatar
jmmartin
so, if i were to run a 10 the length and hardwire in some 14 branching out to each, that outta work, right?
Old May 5, 2009 | 08:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I would use 12 to each glow plug.
Remember, 24 amps per glow plug is the cold draw.
Old May 5, 2009 | 09:52 PM
jmmartin's Avatar
jmmartin
i was keeping in mind something yall had said before about the gp circuits being undersized to keep them from burning up to fast and to balance the factory elec system somehow. but if you say 12 is ok, then thats what i will do... i still have the thinking of a residental electrician...
dbossman
Electrical Systems/Wiring
Aug 29, 2025 10:07 PM
stuemany
Feb 19, 2013 05:34 PM
bobbj
20
Jan 2, 2012 07:15 PM
just2dune
Feb 20, 2011 05:22 PM
jleal_21
Mar 3, 2009 02:10 PM
