Sponsored by: Real Truck
p0354 misfire
Old Mar 24, 2010 | 09:27 AM
stuemany's Avatar
stuemany
p0354 misfire
2003 5.4 f250. rainy day, engine started running with miss, check engine light came on and code is p0354. miss fire in #4. I changed all the plugs and #4 was dirty. started engine and still missing. while running I pulled the connector off each coil one-at-a-time. #4 makes no difference. switched coils from #1 to #4. tried pulling connectors again. #4 still not firing. put volt meter on connector with key on "on", no voltage on either side (or pin), but I see voltage on one side of other 7 coil connectors. I think that the coil is not getting what it needs from the wiring to the coil. how do I fix this?
Old Feb 18, 2013 | 08:56 PM
Minzbig's Avatar
Minzbig
Blast from the past...
Having the same issue with one of mine, p0354 code, replaced the coil with a new one....no change. Swaped the coil with a known good one... No change.
I'm suspecting a signal issue going to the coil. Where do I start?
Old Feb 19, 2013 | 05:50 AM
redford's Avatar
redford
FTE Leadership Emeritus
Start with a close inspection of the wiring harness.
Old Feb 19, 2013 | 04:29 PM
Minzbig's Avatar
Minzbig
After 3 hours of trying different ideas, I started chasing wires and found a wire broke on the driver side about 2 ft from the computer.
Old Feb 19, 2013 | 05:34 PM
redford's Avatar
redford
Good job.
1lrover1
25
Jul 2, 2022 07:39 PM
rolo923
Escape & Escape Hybrid
Mar 2, 2017 06:25 PM
4x4 Nut
2004 - 2008 F150
Apr 16, 2015 02:29 PM
Goof008
Jan 10, 2015 03:11 PM
Flytyme69
Jun 4, 2010 12:21 AM
