Fluid Change
Old May 4, 2009 | 03:31 PM
  #31
patrick77598's Avatar
patrick77598
Originally Posted by miller_feed
Patrick, Ford changed their stance on the front differential fluid. USE 75W-140 IN THE FRONT. Call your dealer and they will tell you this.
does it have to be synthetic in the front or can i use reg?
Old May 4, 2009 | 03:35 PM
  #32
PaysonPSD's Avatar
PaysonPSD
Either is fine.
Old May 4, 2009 | 03:40 PM
  #33
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I used the same fluid in the front and rear. I used motorcraft synthetic.
Old May 4, 2009 | 03:52 PM
  #34
superduty4x4's Avatar
superduty4x4
For the trans fluid, the new "Mercon" labeled fluid is fine for the trans. They re-formulated the Dex3/Mercon and MercV that used to be sold so that now everything runs on one fluid. When I bought trans fluid a year ago, it was hard to find Dex3, only the new blend stuff could be found.
On the trans filter, don't bother. Mark Kovalsky, the guy who worked as a engineer on these trannies, says that if the filter is bad enough to need replaced the trans should be replaced with it.
Old May 4, 2009 | 05:15 PM
  #35
Macamon's Avatar
Macamon
On Diff's... What about:
3 S 405 4
73 2C 5 C821
Really hard to read tag :-\ not too certain about the c821 part
Old May 4, 2009 | 05:59 PM
  #36
PaysonPSD's Avatar
PaysonPSD
3 S 405 4
73 2C 5 C821
How you doin' Mac?
3 73 should be on one line as I typed it. If there is an L between 3 and 7
that means limited slip. If it is a space that means open diff, not LS.
The S stands for Sterling.
405 = Print Number (Model Number)
The 4 in the top line should be a letter, not a number. Maybe its an A.
It's the Revision Identifier (Change in Design)
The 2c5 should be 105 for 10.5 inch ring gear.
The c821 could be 8C21. Check it again. 8 for year built. In this case 1998. C for March and 21 for day in March.
Yahiko
Jul 23, 2014 05:09 AM
Bgrassguitar
28
Aug 22, 2013 03:32 PM
patrick77598
23
Jul 30, 2013 03:42 PM
patrick77598
19
May 7, 2009 12:36 PM
patrick77598
May 1, 2009 08:11 PM
