What is the best fluid
Old 07-22-2014, 10:05 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
What is the best fluid to feed the transfer case with?
I am going to be doing a coolant flush and the transfer case
fluid change and wanted to get some input of the best stuff
to put in. Id the Motorcraft transfer case Fluid just over
priced XYZ fluid?
Sean
Old 07-22-2014, 10:13 PM
bismic's Avatar
bismic
bismic is online now
Received 2,489 Likes on 1,726 Posts
I have no idea if it is better than anything else or not, but I use Royal Purple Synchro Max.
I have used it for 100k miles or so and like it.
Before using it, I contacted Royal Purple and the Technical Sales rep had a good spiel. No regrets so far.
Old 07-22-2014, 10:34 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Darn near anything for the transfer case... If you plan to fill it and forget it for eternity a full syn fluid would do the trick. Mobil 1, Royal Purple, Amsoil etc.
IMHO the Ford Transfer Case fluid is actually Mercon/Dexron III but they won't/can't call it that.
And the bigger mystery is Ford still doesn't recommend Mercon V for the T/C for whatever reason.
Back in my fleet days all Ford T/C's and power steering systems were serviced with Shell Donax TD hydraulic fluid.
Josh
Old 07-22-2014, 10:58 PM
run6.0run's Avatar
run6.0run
run6.0run is offline
I've always used mobil 1 full syn ATF in there. I have been running 100k intervals with no issues.
Old 07-23-2014, 12:25 AM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
I put Mercon V in the Expy transfer case, and would put it in Dan's in a nano-second. Works fine, and the Expy is an active (as in always transferring torque)
transfer case. Ours can take darn near anything short of water...
Old 07-23-2014, 12:38 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
How much cherry juice does it take?
Sean
Old 07-23-2014, 05:09 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Sean
2 quarts....I don't what is best, but I used Amsoil ATF.
fishbones182
1999 to 2016 Super Duty
12-30-2015 07:24 AM
Redneckrucker16
12-30-2013 10:19 AM
crivaro
08-04-2011 11:24 AM
GreatWhite99
09-22-2009 12:37 PM
straightsixer
04-21-2008 03:37 PM
Quick Reply: What is the best fluid
