Transmission fluid
This is part of a article, "We aren't yet replacing SP, which is used in our conventionally shifted 5 speed and 6 speed transmissions, but there is a significant amount of testing ongoing to replace SP with Mercon LV"
LV stands for low viscosity.
It appears to be designed for cars and light-duty trucks (not Super Duty or the Torqushift transmission).
It is a 150,000 mile fluid and appears to be an improvement for Mercon V?
Here are some links:
MERCON® LV Automatic Transmission Fluid
LUBE REPORT: Ford Unveils New Transmission Fluid
CarTech, Inc.: Browsing Selecting the Proper Automatic Transmisison Fluid
Wow... there is no way I would go 150,000 miles between fluid changes in any vehicle. I am very surprised to hear that Mercon LV is used in an '09 Super Duty per a previous post above???
Not every dealer even has or uses a flush machine for transmissions.
I have not seen a copy of an owner's manual nor have I seen any posts in the 6.4L PSD forum about Mercon LV fluid in '09 Super Duties.
Check the owner's manual for your friend's truck and verify the fluid type? I can't seem to find anything about Mercon LV being the factory fill in any model year Super Duty truck.
Is there a resident diesel tech viewing this thread that can assist and can look it up in the Ford Service manual and on-line system?????
Thanks,
It appears to be designed for cars and light-duty trucks (not Super Duty or the Torqshift transmission).
CarTech, Inc.: Browsing Selecting the Proper Automatic Transmission Fluid
Reread a few posts above.
FORD UNVEILS NEW TRANSMISSION FLUID.
The purpose of the Mercon LV is to replace Mercon SP. Super Duty is a trade name, F250 F350 are light duty along with the chevy and dodge trucks.
What is your reference for it not being a synthetic? I have not been able to find an official source (that I can remember) that states specifically that it is or isn't.
The fluid can withstand some high temps, which leads me to believe the perspective of it being a synthetic. It sure would be informative to confirm this either way!
I make my assumption based on the following two knowns.
1. If you read the SP bottle, and I read every word even the fine print, there is no mention of it being a synthetic fluid. I would think since synthetics have become very popular for all drive train components that Ford would say whether SP is synthetic or not. Just my observation.
2. On another post that discussed SP add nosium, in rebuttal to my saying that SP was not synthetic, there was an article posted that used the word synthetic in it when discussing SP but it did not say specifically that SP is synthetic. I believe the article stated that ford may reformulate SP and that a synthetic base MAY be required in the reformulation. I tried SEARCH to find the thread but had no luck.
Again, this is not difinitive but just the info I drew my conclusion from that SP is not a synthetic tranny fluid. FWIW
I put Royal Purple synthetic ATF in my X at 60,000 miles and it now has 78,000 miles on it. The only difference I notice is that it shifts a little firmer. Firmer shifts are not uncharacteristic of synthetic tranny fluids. B&M Trick Shift, which I used before RP ATF, is a prime example of what I'm talking about.
Has anyone read the new LV fluid bottle to see if it is a synthetic fluid?
DSMMH
