which power steering fluid?
Old Jul 8, 2006 | 09:20 PM
dbuck50's Avatar
dbuck50
I have a 93 F150 4x4 and I have started leaking PS fluid and I think it is the pitman shaft seal.
I saw an unclear post saying that this model/year should be running TypeF ATF fluid for PS fluid and that regular PS fluid is bad?
I have been using PS fluid but ran out and put in some Dexron.
Am I making things worse? Should I be using TypeF or Dexron? or will regulary PS fluid be ok? What's the diff between PS and TypeF?
Thanks.
Old Jul 9, 2006 | 08:53 AM
Lou Braun's Avatar
Lou Braun
Your truck lists type F ATF as the correct power steering fluid.
The different types of ATF fluids were designed to be specific to a particular type of automatic transmission. Each type of ATF has different friction characteristics that is important to the clutch assemblies in an automatic transmission.
In a hydraulic system such as a power steering sysem, these differences are not as important. Bottom line, PS fluid, type F or Mercon would all work OK in your power steering system. I would use type F if it was on hand, but having the sytem full would be far more important than the type of fluid.
Lou Braun
Old Jul 9, 2006 | 09:16 AM
pfogle's Avatar
pfogle
Type F or mercon will help with the "whine" that all ford p/s systems seem to have. To give you an idea my 2001 Windstar calls for mercon in the power steering. PS fluid has less friction modifiers and makes the pump a little louder.
Old Jul 10, 2006 | 04:42 AM
pinerider's Avatar
pinerider
Pitman arm seal replacement can be a PIT job, from what I've read here. I have an 87 F150, just changed the steering box to solve a pitman arm seal leak, wasn't too bad of a job. Seach this forum for "pitman arm seal" or "steering gear" and you'll get lots of info.
Old Jul 10, 2006 | 09:05 PM
stresssolutions's Avatar
stresssolutions
I guess I got "lucky" because when mine was leaking around the pitman arm, I got hit in the left front, which caused a major pitman arm leak and got a new steering sector out of the deal. Sure looks like a PIA job.
Old Jul 11, 2006 | 01:30 AM
Lone Wolf #2's Avatar
Lone Wolf #2
After three pitman arm seals, replaced steering box, no more leak there. It is a PITA.
daggerNC
Jun 3, 2007 10:45 PM
fordracer08
May 23, 2007 06:23 AM
76390FE
Dec 11, 2003 12:57 AM
rusty70f100
May 3, 2003 06:36 PM
76_F150_390
Nov 21, 2002 03:49 PM
