Sponsored by: Auxito
Power Steering Fluid
Old Nov 26, 2005 | 12:08 PM
kntryboy's Avatar
kntryboy
I have a F-150, 2001, 4.6L truck. My owners manual states to use Mercon ATF fluid for the power steering. I went to a Ford parts house to buy the power steering fluid for the above and they sold me power steering fluid for type F applications and said that this was the correct type of fluid.
Is this correct? Are these two type of fluids interchangeable?
Thanks,
Old Nov 26, 2005 | 04:07 PM
xspeedyx's Avatar
xspeedyx
I am useing mercon dexton synthetic mobil 1 ATF in mine. I trust the manual more than the parts guy.
Old Nov 27, 2005 | 07:48 AM
steve(ill)'s Avatar
steve(ill)
the type of fluid used in the steering is not critical due to the dseign of the system. it is not advisable to mix fluids in any system. i would choose MERCON, MERCON V, TYPE F, etc, and stick with that. Adding two of the above together is not critical, but shoudl not effect teh steering in a bad way. it is more important that it is clean and full, then what type of fluiid is used.
Old Nov 27, 2005 | 06:07 PM
whimsey's Avatar
whimsey
Stick with the Mercon spec fluid for your PS. That's what Ford specs. It's cheap enough. Why use a fluid that could possibly cause problems .
Whimsey
WillF250
Jun 3, 2011 10:41 AM
sigtauenus
Apr 2, 2010 11:30 AM
jdr37
Aug 11, 2009 06:30 PM
mike L
Oil & Lubrication
Mar 30, 2006 02:56 PM
Smith76
Mar 8, 2006 09:11 AM
