I have a 2004 F150 4x4 Automatic. When the trans shifts to overdrive it feels like neutral.When i turn off the overdrive it runs through the gears fine.NO codes came up.Any help would be appreciated
The OD band is burnt or broken, or the overdrive servo has blown out of the case due to a problem with the snap ring that holds into place. Unfortunately this means that it will have to come out to be repaired, the overdrive servo wont index the band unless it is held into place from the inside, so you cant just put it back in.
