Modular V10 (6.8l)
overdrive off around town? when?
Old Apr 8, 2005 | 03:28 PM
THRODS's Avatar
THRODS
Question overdrive off around town? when?
I have a 2001 F250 SC 4x4 w/ the v10 AT w/ overdrive
when do you trun the overdrive off? when should I leave it on?
I drive ten miles to work on the hwy at 65 miles per hour, and then 5 miles through town at stop and go traffic.
should the overdrive be off during town/city driving?
Old Apr 8, 2005 | 05:36 PM
Munkey's Avatar
Munkey
Just leave it be. The only time you'd really need to turn off the overdrive is if your transmission is constantly hunting between 4th gear (overdrive gear) and 3rd gear. This mainly occurs while towing in areas with hills to climb.
Old Apr 8, 2005 | 06:57 PM
V10KLZZ71S's Avatar
V10KLZZ71S
I leave mine off around town because usually you drive around 40 mph and the trans is shifting back and forth at that speed.A trans mech told me to leave it off around town.If you are driving at 40 or below it makes no difference.
Old Apr 8, 2005 | 07:12 PM
CmprSpecial's Avatar
CmprSpecial
I leave it on all the time unless, like others said the trans is hunting. That only happens when towing. The computer learns your driving habits and adjusts it's shift to your driving style over time. If you turn the OD on and off, it may never get it right.
Old Apr 8, 2005 | 07:13 PM
race8x98's Avatar
race8x98
Leave it on. When driving rural roads it will drop out of OD on hills at lower speeds but the downshift from OD to 3rd is not a big deal, sometimes don't even notice.
Old Apr 8, 2005 | 07:59 PM
nisiar's Avatar
nisiar
The owners manual will make suggestions about the intended uses of the overdrive button, however, an un-documented (but effective) use is to button out of overdrive just as you turn into a high speed turn. This will cause the truck to surge forward, settling the suspension, adding weight and grip to the front wheels, allowing a more aggressive entry into the turn. Of course, the lower gear and more direct application of torque helps tpo!
Old Apr 8, 2005 | 09:33 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Or, when a victim pulls up next to you at around 60 mph, ease it out of od, they hear the 6.8's revs increase slightly, then at that point they are screwed.Nail it and my rpms reach about 4800 instantly,rev to 5200 and shifts back into 3rd-bye bye.
Old Apr 8, 2005 | 09:43 PM
Fredvon4's Avatar
Fredvon4
THRODS my vote , given your commute trip, is to just leave it on.
Because you are asking now, and the truck is 4 years old, I assume you just picked it up used recently.
If that is true, there may be some small benefit to removing the battery cable over night Sunday. Monday when you hook it back up the adaptive learning process will begin to check your driving habits out over the first three or four "driving cycles".
Old Apr 9, 2005 | 01:57 PM
THRODS's Avatar
THRODS
yes
I just bought it
We just sold our 2000 excurson w/ 100K
she down sized
and I bought a new Ford
she had the v10 in the excursion,
when we bought it they told her not to touch the overdrive
I guess I never thought about it again!
talk to me about unhooking the battery cables?
why?
thanks in advance
this is a great web site!
Old Apr 9, 2005 | 03:10 PM
Munkey's Avatar
Munkey
You unhook the battery cable to 'erase' the adaptive computer memory. The previous owner could have been *****footing it around town, and the transmission would shift as such, or he could have had a foot made of lead.
It basically clears the computer so it can learn for your driving style.
Old Apr 9, 2005 | 03:56 PM
race8x98's Avatar
race8x98
To be specific, unhook the negative battery cable for a while, when you reattach it the computer will reboot and be ready to learn your driving style.
Old Apr 12, 2005 | 10:16 AM
ken04's Avatar
ken04
Yea I hate being in a 40 mph zone, that's the only time I turn my OD off also, other than that, I leave it on while not towing. And I tow with it all the time, unless I'm in gentle hills where it may hunt, otherwise it kicks down and stays there so I have no problems.
Old Apr 14, 2005 | 12:14 AM
Shepard's Avatar
Shepard
When I see the rpm's dropping on a long hill, I'll punch the OD button to take it out of OD before it does it on it's own. If I forget, it will downshift with a roar and a lurch. Scares the children, you know!
My truck has always seemed to over downshift, (for lack of a better description). Comes out of OD, rpm's jump way up for several seconds, then shifts again into an intermediate spot that takes it up the hill. If I punch off the OD before it does that, it just goes smoothly down into that intermediate spot and will climb anything without loosing a bit of speed.
Old Apr 14, 2005 | 09:57 AM
ken04's Avatar
ken04
It shifts like that when the tq converter unlocks, then goes into 2nd or 3rd gear until the tq converter locks up again. I do what you do, if I start dropping revs and I know it's going to shift down, I de-OD. I also do it because I have enough power to get back up to speed where the OD will kick back in, then the process starts over. But unless I'm in fairly steep hill country OD hauls us around fine with the camper on the hitch.
Hunt4Fun
Feb 1, 2012 07:53 PM
hatchet
Jun 13, 2010 03:57 AM
donybrk
2004 - 2008 F150
58
Jun 27, 2007 03:32 PM
n2baja
17
Nov 18, 2005 11:37 PM
gwinters
1997 - 2003 F150
Jul 22, 2002 01:28 PM
