Overdrive vs Drive
Old Oct 27, 2003 | 07:48 AM
donybrk's Avatar
donybrk
Question Overdrive vs Drive
I have the 04 SCrew 4x4 and I am not sure when to use drive and when to use overdrive. Someone stated that you should use drive when towing and overdrive for every day use?
Old Oct 27, 2003 | 08:39 AM
bigbluebronco43's Avatar
bigbluebronco43
I've always used the overdrive in every car I drive. I think in the early 90's with the Taurus's people would use Drive only because the shift to Overdrive came too soon. Supposedly with the new 5.4 the truck doesn't need to downshift while towing uphill but if you have the smaller engine then you may need to just use drive. I would say leave it in overdrive.
Old Oct 27, 2003 | 11:46 AM
andym's Avatar
andym
The reason you hear that you should tow in drive is because the truck has a greater tendency to downshift for every little upgrade when pulling a load. As long as it's not shifting between gears constantly, leave it in O/D, but pay attention to it. Frequent shifting between gears will ruin your tranny.
Old May 21, 2007 | 11:13 AM
jackie wray's Avatar
jackie wray
Talking overdrive vs drive for better gas mileage
Hi. I just have a couple questions. I drive my truck in overdrive because it defaults to overdrive. My reasoning is if it was the otherway around it would default to drive! Now my dad told me that yes on the interstate (my route to work) at 65-70 miles per hour use overdrive but in congested areas (stop and go) use drive. Use drive when climbing a mountain or pulling a trailor or climbing and mountain while pulling a trailor! What is the best way to drive using overdrive and protecting my tranny AND getting the best gas mileage.
Also, is it true if you drive w/tailgate down you will get better gas mileage?
Thanks
Jackie
wraybabe@hotmail.com
Old May 21, 2007 | 12:03 PM
LeoSV's Avatar
LeoSV
Thanks
Jackie
You should just use O/D all the time unless you're going to be stop and go below 35 or 40mph. All it does it prevent it from going into 4th. Just do like you would if you were driving a stick. would you constantly be shifting from 4th to 5th inside the city? probably not. and I actually read that trucks are designed to be more airstreamed with the tailgate up because they get a pocket of stagnant air in the bed and the other air just goes over that. with the tailgate down, the air behind the cab is constantly moving and creating more drag. I'm not a scientist, but this is what I heard. either way, I leave it up. I had a nissan Pickup and did a long road trip with it. left it up in one direction and left it down in the other. there was absolutely no change in MPG at all.
Old May 21, 2007 | 12:09 PM
irishammer's Avatar
irishammer
According to the local tranny repair shop...NEVER start out in OD when towing!!! He said you can shift into OD after you are up to freeway speed..let off the gas shift into OD then go. If it shifts in and out often only use Drive. If you start out in OD when towing excessive heat is generated. My cousin towed a small pop-up with his 1994 F-250HD with the 460 and always towed in OD. After a hefty repair bill he won't do it again.
Old May 21, 2007 | 12:31 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
So long as the tranny is not 'hunting' for the correct gear (4th or 5th), you can use overdrive. Read your Ford manual! Even when I had my '92 the manual said to use overdrive when towing....except in the hills/mountains, then lock it out. 'course in my new(er) '05 PSD you can not even make a selection to lock out overdrive. No switch.
Old May 21, 2007 | 02:03 PM
jackie wray
thanks so much
wow, this club is great! I just signed-up today, asked my questions and got responses w/in an hour or so. thanks for your input - a big help to my unknowlegable (only had the truck a few months) brain!!!
Old May 21, 2007 | 04:10 PM
jsonh's Avatar
jsonh
i have an 05 f150 with 196k miles on it. most of those miles are towing miles. since ive owned i have always turned the o/d off when towing and left it on when i was not towing.
Old May 21, 2007 | 04:55 PM
mattd17's Avatar
mattd17
the biggest problem i ever heard of with the OD vs. Drive was for the early - late 90's dodge's.... and that was due to a bad gear ratio on the planetary gears. but now its not as bad. i guess it just depends a lot on how much you are towing, your driving style, and road conditions. for every day driving, i have never had a problem leaving the OD on. as for the tailgate up or down issue, i think mythbusters tested this one, and the result was that it was better to leave it up. when the air comes for over the cab, it will actually swirl at the rear of the bed, and then go towards the front, and push the vehicle.... this is easy to se... just put an empty plastic bottle in the back, and drive down the road... it will get pushed forward by the wind. i always leave mine up for one reason more than the rest.... that is to avoid the tailgate from bouncing when i go over bumps.
Old May 21, 2007 | 06:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
That makes no sense. Do you think the tranny shop even knows what overdrive is?? there's is no way you could start out in it unless you have a stick and even then...
Heat is built when the tranny shifts. Too much shifting means too much heat. Too much heat ruins trannys.
Old May 21, 2007 | 07:48 PM
4DOORSR's Avatar
4DOORSR
Nice! Highest I've seen yet. Sorry off topic.
Old May 21, 2007 | 07:55 PM
easttxguy37's Avatar
easttxguy37
my truck wont kick into the last gear (overdrive) if the overdrive button is turned on. it jsut stared doing this. if the overdrive button is turned on, once it tries to shift into that last gear, its like it goes into neutral. if i turn the overdrive button OFF, it works fine, just runs on high RPM's.
does this mean my tranny is goin out?
Old May 21, 2007 | 08:51 PM
irishammer's Avatar
irishammer
Of course you don't start in OD.... If you have OD selected is what I meant. If you chose to do so have at it...it is your money!
Old May 21, 2007 | 08:53 PM
irishammer's Avatar
irishammer
easttx My 1992 did the same thing...when the tranny tried to go into OD it would just rev up....got rid of it. I would just keep OD off and had no other problems. Did that for a couple months at least.
