74' 302 Headers
Old Apr 28, 2009 | 07:03 AM
gtuttle's Avatar
gtuttle
74' 302 Headers
I am replacing my old 302 (1974) w/ a rebuilt 302 (1970) & ordered headers from Summit Racing. Tried to put engine in w/headers on, you know what happened there. After getting engine in attempted to put headers on. Took off the starter, the heater core housing (factory air). Loosened up the motor mounts etc. Still will not go in from underneath (which is how Summit said to do it after speaking to them about this problem, they said no problem just come up from the bottom) nor from above. After about 2 days of trying to figure it out finally gave up & put old exhaust back on just to move forward.
My final thought is to just get it running & take it to a muffler shop, is it worth it to have headers on this or not or was it just wishful thinking.
Thanks
Garry
Old Apr 28, 2009 | 07:14 AM
Dforgy's Avatar
Dforgy
Welcome to the world of headers Even in a truck with enough room for a pool table under the hood, your going to fight them to no end.
I'm assuming it's 2 wheel drive right?
Old Apr 28, 2009 | 07:32 AM
gtuttle's Avatar
gtuttle
forgot that one, yes 2 wheel drive
Old Apr 28, 2009 | 09:04 AM
jsutton's Avatar
jsutton
You can get them in from the bottom on the passenger side. I have a 77 with a 302 and Factory air box. What I did was remove the starter, cut the transmission cooler hard lines and replaced them with approved transmission cooler rubber lines, then I removed the radius arm crossmember. I also had to undo the passenger side motor mount nut that goes through the perch and loosen the driver side one so I could raise the passenger side of the engine. There was thread a while back where I said this and someone said they did the same thing except they didn't remove the crossmember. EDIT: I did reinstall the radius arm cross member after I got the headers in!
Also the headers are going to exit right into the tranny crossmember so you're going to need to get around that too. I just used a set of headman collector extensions with S bends in them Hedman Hedders 18804 - Hedman Universal Header X-Tensions to get the exhaust routed up and over the cross member other people have fabbed up their own way to get around this problem.
Good luck, they will fit.
Old Apr 28, 2009 | 09:21 AM
gtuttle's Avatar
gtuttle
This sounds right to me, I figured it would take some re-engineering, according to Summit all you had to do was "just put it in from underneath".
Thanks
Garry
Old Apr 28, 2009 | 10:10 AM
Poison Oil Racing's Avatar
Poison Oil Racing
Thanks
Garry
LOL. Basically they were correct, but I had to loosen my motor mounts at the perches and lift the engine up to get them in.
Surprisingly the passenger side was harder than the drivers side. The drivers side just slid in.
Old Apr 28, 2009 | 10:13 AM
jsutton's Avatar
jsutton
Yea, my driver side went right in from the top, easy as pie.
Old Apr 28, 2009 | 10:46 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
gtuttle
I installed my first set of headers ( 26 years ago ) and I will tell you its not like I got them
to go right in cause they gave me the hardest time I have ever had, I amost ( THREW )
Though the windsheild , but I sayed with it till I got the from the top ! Years later header
install is one of the ( Easiest ) things you will ever do follow what I say in the links that
I post and It will go real ( EASY ! )
https://www.ford-trucks.com/forums/682205-headers.html
https://www.ford-trucks.com/forums/6...r-trouble.html
https://www.ford-trucks.com/forums/7...-feedback.html
https://www.ford-trucks.com/forums/7...-65-5-0-a.html
STILL adding links>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>
Wally Womack
Last edited by Pro-Street/StateTK; Apr 28, 2009 at 10:50 AM. Reason: watching my Ps and Qs
Old Apr 28, 2009 | 10:50 AM
gtuttle's Avatar
gtuttle
thanks everyone, looks what I need to do is more work but should be worth it ...
GT
ken selvy's Avatar
ken selvy
Go with shorties from summit and easy install from top , why fight it ? My 2 cents .
Old Apr 29, 2009 | 06:21 AM
gtuttle's Avatar
gtuttle
will give it a look over
thanks
Ken
ColtonMullis
24
Jun 6, 2016 08:39 PM
Lagniappe
Jun 9, 2015 12:37 PM
vtpkrat2
Mar 19, 2015 05:56 AM
Tedster9
Feb 11, 2015 09:51 AM
specrocz
1997 - 2003 F150
Sep 27, 2010 09:40 AM
