right bank not firing
well according to this post this must not be very common at all. just got it back from the dealer ($85 dollars later)and cost of a tow to prevent any further issue, all they can say is its pointing to a timing issue as if the chain has slipped. not very happy with the diag. still looking for some clues before tearing into it.
hi
its a constant no fire on right bank, ford garage used whatever electronic equipment to test and said it seems to have good compression,and that all seems to check out good. they want to tear into the front timing cover to know for sure. obviously they dont want to check compression the old fashion way(through the cylinder head) because of the plug issues. I have driven the truck when I had to for diagnostic and etc, but am afraid of bending valves,if this is the problem. getting ready to take truck to a ford mechanic(who now has his own shop) he will probably tear into it tomorrow. truck will bearly stay running at this point. any last minute knowledge? or even educated guesses? thanks
I fogot to say in my last post, to be sure to let us know what they found.
truck has 80k mi, now at the mechanics place, could hardly make it there with it yesterday, it seems as if on plug on the left is now fouling out almost had to be towed the rest of the way there last night. this truck had the ext 75k mi plan on it I wonder what the chances of getting any help from ford would be? yes I did unplug the injectors on the way there last night, but have previously driven the truck with them plugged in. so just hoping the cats are not a problem now. thanks
