P2262 Code
Old Apr 23, 2009 | 12:51 PM
jeklhyde's Avatar
jeklhyde
P2262 Code
There must be something in the water considering all the turbo issues. Truck threw a P2262 (no turbo boost) code this morning on my way into LA. Checked hoses looked good with no other obvious causes. Truck is understandably sluugish but shows no other issues. Coolant/oil temps normal. Exhaust is normal. No strange noises.......etc.
Question is-I'm about 225 miles from home and safe haven. Should I chance the drive home as is or?
Thanks
Miles
Old Apr 23, 2009 | 01:27 PM
steelhead2's Avatar
steelhead2
i would. even if you make it 100 miles it'll be cheaper than a 225 mile tow bill. it'll probably even get you home. sounds like the vanes in your turbo are stuck.
Old Apr 23, 2009 | 01:46 PM
riggz's Avatar
riggz
Year of truck and mileage would help and are you towing anything?
Old Apr 23, 2009 | 02:16 PM
jeklhyde's Avatar
jeklhyde
thanks guys.
'06, 137K, no tow. Freeway all the way with just one major grade (the Grapevine).
Additionally, where does the PCM register boost from?
Old Apr 23, 2009 | 02:34 PM
riggz's Avatar
riggz
Well your clearly out of warranty range but you should be ok. Just keep an eye if anything starts to change. Your MPG is probably really low correct?
Old Apr 23, 2009 | 02:39 PM
jeklhyde's Avatar
jeklhyde
MPG is hard to tell at this time. Intial observation makes me think it's not too bad. I have been babying it though and not getting aggressive. Once up to speed I'm hardly in the throttle at all. Since it's all freeway I might be getting lucky in that regard.........
Old Apr 23, 2009 | 02:41 PM
riggz's Avatar
riggz
Well my question is you said it's understandably sluggish. So has it always been sluggish or did it just start when you noticed the code? Did the code set off the check engine light?
Old Apr 23, 2009 | 02:50 PM
jeklhyde's Avatar
jeklhyde
When I was pulling the grade this morning, before I realized there was an issue, I had to floor it for passing speed. That's what tipped me off. No CEL but my Hyperpac gave me the DTC. Truck was usually very responsive.
From a standing start the truck is sluugish is what I should have said...
I'll watch the guages and make sure it's all good as I go home. I'll let you know how it turns out.
Any thoughts on where turbo boost is monitored from?
Thanks again.
Old Apr 23, 2009 | 07:16 PM
bismic's Avatar
bismic
P2262 - possible causes:
MAP hose
MAP sensor
CAC system leaks
Intake leaks
EP sensor
Exhaust restriction
Old Apr 24, 2009 | 09:57 PM
woodys06's Avatar
woodys06
Well very good news. Bismic you are partially correct. Intake leak......
It was the turbo boost sensor. Apparently the nipple had broken and disconnected from the intake manifold. Probably cracked when I was performing the EGR delete a couple weekends ago and then completely failed from the road vibrations etc. I also surmise that since this caused a DTC that the PCM went into safe mode and resulted in the loss of power rather than the turbo actually not functioning.
$101 dollars at Ford and I'm back in turbo boost.
Thanks for all the input.
(BTW this is my home personna-I'm jeklhyd at work)
Old Apr 24, 2009 | 10:03 PM
bismic's Avatar
bismic
Glad you got it worked out (and for a reasonable price as well). Also - thanks for posting the solution - I try to keep track of these things in my spreadsheet (but it is almost getting too big).
Old Apr 11, 2010 | 11:00 PM
ash289's Avatar
ash289
I know this is an old post but this happended to me today. Check engine light came on when I lost power. Some black smoke according to friend following me in car.
Stopped at Advance to get code checked and found out P2262 - turbo boost pressure not detected
I was only a few mile from my stop. 4 hours later, cranked it up and it ran just like normal. Plenty of power. 1.5 hr trip home on interstate 70-75 mph.
Any suggestions for sporatic situation?
Old Apr 11, 2010 | 11:02 PM
ash289's Avatar
ash289
BTW - E450 Ford shuttle bus. 2004, 6.0, only about 45000 miles.
Turbo replaced summer of 2008
Old Apr 12, 2010 | 10:33 PM
m-chan68's Avatar
m-chan68
The last E-Series I had that threw that code specifically was caused by the catalytic converter being restricted due to the internals coming apart. Something you can check yourself very quickly is to give it a tap from underneath. If you hear it rattling a little, that's your problem. Another thing you can try is disconnect the downpipe from the turbo temporarily, and drive it to see if full power is restored. These two tests will tell you very quickly whether or not the exhaust is restricted.
thegreatgate
Aug 12, 2016 08:44 PM
Chipper j
Apr 12, 2016 12:28 PM
jeffy17
Jun 16, 2015 08:01 PM
SubZero
Feb 14, 2012 07:20 PM
teague350
Sep 30, 2011 04:49 PM
