2007 6.0 diesel no boost, a ton of codes
2007 6.0 6 speed, 187,000 miles. The other day started truck, had been running about 20 minutes before. Started fine, go to drive, chugging white smoke, smelled like unburbt diesel, baby truck home, seemed to run ok at low rpm, truck warmed up and ran fine. But I also noticed turbo boost was acting funny. Truck ran fine next few days. Then this morning, started cold fine, started to drive it and same chugging white smoke, it quit by the time j got to the end of my driveway, but drove to work, it quit smoking, ran pretty smooth, but will not build any boost. Truck is bone stock except for exhaust, it's straight piped. Ok. So this eve I borrowed my dads edge cts, here's all the engine codes
P0069
P0269
P0299
P2262
P2269
The last one is water in fuel, since it started this crap I did notice it was right after it came on in the dash
I'm trying to figure out where to start
Thanks for any help you can give
On another note. VGT duty shows 85% at idle ?
Ficm voltage is constant 48 volts
Newer batteries
P0069
P0269
P0299
P2262
P2269
Newer batteries
have you drained the separator since it came on? takes a 6mm alen key.
be careful not to strip it.
also did the cylinder 4 go away? and just have cylinder 3?
hopefully some fresh t6 oil and maybe some archoil or Rev x.
personally I've used Rev x and had 2 balance codes go away in about 300 miles. they eventually came back but it got me about 8 extra months out of them.
