power adder
Old Apr 18, 2009 | 02:21 PM
429PI IN 75 f-100's Avatar
429PI IN 75 f-100
power adder
What is the best cold air-intake and exhaust for my 95 F250 i was looking for dual exhaust but these are rather expensive
Old Apr 18, 2009 | 02:26 PM
Brown Falcon's Avatar
Brown Falcon
The best intake is one you can make yourself for pretty cheap... It's refered to as a Tymar or 6637 mod
Basically remove the old air box, put a 45* bend piece of 4" pipe in to the intake hose and put a Napa 6637 filter on that sits where the box used to be.
Cheap and flows a lot better. Some guys use AFE filters and other re-usables, just DON'T use a K&N. The paper 6637 works great though.
As far as exhaust, get a 3" downpipe, delete the cat, and straight pipe it wherever you want it. Most guys i've talked to make their own exhausts for it. I did 5" stacks and i love them!
Brown Falcon
If you want pics of the 6637 mod let me know
Old Apr 18, 2009 | 10:04 PM
c00nhunterjoe's Avatar
c00nhunterjoe
Old Apr 19, 2009 | 04:24 PM
thumper869's Avatar
thumper869
so whats wrong with the k&n?
Old Apr 19, 2009 | 04:58 PM
don77's Avatar
don77
k&n is not good it lets dust and dirt get in
Old Apr 19, 2009 | 05:12 PM
thumper869's Avatar
thumper869
now that i don't understand i check my filter and intake tube every five thousand and nine times out of ten the tube is clean as a whistle. i have k&n's intake and filter on my 97 psd. i've never had any trouble out of them and have used their filters and what not for several years now
Old Apr 20, 2009 | 07:08 PM
429PI IN 75 f-100
I would like pictures of the air intake mod Brown Falcon and how much did it cost in general
Old Apr 20, 2009 | 07:56 PM
tjbeggs's Avatar
tjbeggs
If you have a drop in filter in your stock box consider your self one the few. The complete intake systems work better. The stock boxs is trash. Its made much worse when you add a K+N filter. The rubber surround is too hard to seal correctly and IMO every K+N I have have ever seen has way too big of voids to filter the air in my truck.
Cost can vary from $40 to 150. here is a picture of mine that cost some where around $100. Picture is from when I had it on my 95.
Old Apr 20, 2009 | 09:00 PM
429PI IN 75 f-100
I have seen were people take and clean up the in intake tube and exhaust at the turbo does any one know more about this and how much it helps and does any one know how much trans fluid it takes to fill the truck my book says around 16qts the trans is an auto and did the 95 come with a garret turbo stuck from the factory also thanks for the previous info it is very helpful
Old Apr 21, 2009 | 01:34 AM
thumper869's Avatar
thumper869
i have had the complete intake system for several months now and had the drop in before and like you said the whole system blows the drop in away and just ordered a tw chip for it today
Old Apr 21, 2009 | 04:15 PM
Brown Falcon
1. there isn't much you can do to the intake tube at the turbo...
2. for the trans i'd put in about 14qts to start then check it and then just add a little at a time till it's full. you aren't going to be able to get all the trans fluid out
3. all of our trucks came with garret turbos stock
ROKRAWL
24
Aug 7, 2013 12:19 AM
49 Ford F-1
Sep 24, 2012 07:26 PM
IRUNUOVER
Exhaust Systems
17
Jun 22, 2009 06:51 PM
95F_150
Exhaust Systems
Nov 15, 2001 11:09 AM
rotorhead
Sep 5, 2001 09:37 PM
