I have tonys tunes and i am going to be changing my setup to some 250cc hybrids and a modded h2e. Now the guy i talked to said that my tuning will be almost the same and my extreme will be exactly the same. Does this seem right to you guys, because i heard you can really do some damage with a setup like that and the wrong tuning??
the tuning will probably have to be different or it will fuel too much in the wrong areas, plus timing may have to be changed...
talk to tony about what you have done, if you're not 100% confident in that go to swamps and they'll treat you right too
i would suggest away from jody's stuff (dptuner) just because you hear of a lot more windowed blocks from his tuning
edit: plus the computer will have to be forced to throw more fuel in, higher HPO, blah blah...
